wilharper2000
- Joined
- Sep 15, 2006
- Location
- UK
- TDI
- Golf 2 GTD 80HP (SB), 2001 Audi A6 115PD TDI (AJM), Polo 1.4TDI (AMF)
I’ve just spent the day removing and replacing the thermostat on my Audi A6 1.9TDI-PD. The job went really smoothly. I used all genuine VAG parts including a new pipe thing that goes on the thermostat. Then filled it up with 50:50 G12 ++ and de-ionized water.
The car has taken just under 5ltrs, I only removed the bottom pipe on the radiator to drain the coolant so I’m not sure much or any more came out. (BTW I did turn the new thermostat 90 degrees in the pipe to secure it)
Anyway I started the car and held the revs at 2000rpm for about 5mins maybe a bit more. The gauge went to about halfway between normal temp and cold, the oil temp went to about 60-70C. I turned off the car at this point because I didn’t feel something was right. All the rad pipes are cold, the heater is working but the little water pipe going into the top of the expansion tank is not squirting water when the car is running. When I squeeze the top pipe it does squirt.
I’m worried there is no water in the block as the temp gauge read higher after being turned off then it cooled down very quickly. Would the car get up to temp properly just revving idling. I’m worried if I take it out it will overheat.
Any help would be great
Will
Will
