Wet Front Passenger Floor - NO SUNROOF - Gasket Failure?
I've had a repeated water infiltration problem during periods of heavy rain in the last year (especially in cooler weather). The water keeps pooling in the front passenger floorboard of my '01 TDI - NO SUNROOF. I've pulled the carpet up and dried the carpet pad; I left the carpet folded back and ran a test with a water hose to try to find the problem. With the front right dash panel removed, I can see the water draining into the plenum and out the drain into the front right fender well. I've removed the wheel well liner; it is free of debris. When enough water comes into the plenum via the drains in the cowl, water does pool up against the cabin air filter enclosure (but not over the top). The only possible entry point I can find is around the cabin air filter enclosure. I just found a similar problem with Passats.
Has anyone else had this particular problem that couldn't be explained by clogged sunroof drains, clogged cowl/plenum drains? My car has no sunroof, and the drains are completely clean, but I still collect water. When I run the hose on the cowl/wiper area, I can see a small stream of water running down the front firewall. This afternoon, I coated the cabin air filter housing gasket with silicone adhesive sealant in hopes of stopping the leak before rains come again this week. We'll see what happens. Any thoughts?
I also posted this on newbeetle.org, but I thought there might be some forum members over here that could help out. Somebody else has to have dealt with this.
VWvortex Forums: VW Service Action P9 (water entry)...anyone else?
