Old April 15th, 2015, 15:23   #1
evantful
Fuel Economy: 44.3 AV
Default Bizarre DSG Rattle 2-5mph
Hi all,
I have 2013 DSG JSW TDI with about 33k miles on it. Around 13k I noticed a sudden noise appeared when moving 2-5mph. Its a pretty pronounced rattle coming from the front drivers side and a very noticeable shaking. It seems to be coming from the transmission and occurs pretty consistently. Others who are not mechanically inclined(or anal about it) have noticed it to and asked if there was something wrong.
I have had two other DSG cars prior, so Im use to there quirks and roughness (which never bothered me). This is something I have not encountered.
It almost sounds like the DMF but it doesn't rattle when in park. Also I noticed that If I tap the brake pedal a lot of times it you can feel an engagement in the transmission and the rattle stops (but not all the time... its almost like the clutch is failing to engage properly.
Ive removed the belly pan to make sure it wasn't vibrating.
Heres a link to a video I shot of it. Its louder than in person than the video:
https://youtu.be/ZIhre97V0Gw
I brought it in once and the dealer set the DSG back to basic settings, but didn't effect in it any way. The one service person I dealt with told me "they all do that".... the line everyone gets with a DSG problem.
Anyway I just wanted to see what you guys think and ultimately get on VW to figure this out
evantful is offline   Reply With Quote
Old April 15th, 2015, 16:59   #2
skinnyb
TDI(s): 2013 JSW TDI
Fuel Economy: Slightly north of 40 MPG
Mine has done this since day one. Has 62k on it now (most of them with Malone tune) and it hasn't gotten any worse. Funny thing is my Passat or my R32 don't do it at all.
2015 Passat 1.8T Limited Edition
2013 JSW TDI DSG Malone 2.0 Eco, Tint, Wheels, Etc...
skinnyb is offline   Reply With Quote
Old April 16th, 2015, 15:29   #3
azthegame
It's because at that speed, your dsg is on the line of 1st and 2nd gear. It's in second but kinda wants to go to 1st but doesn't. It happens all the time for me especially when creeping on a drive thru window for fast food. When I am in D, it's in second as I am creeping, but if you flip it to manual mode, it goes to 1st and the rattle instantly stops. Hence why I am almost positive my theory is accurate.
azthegame is offline   Reply With Quote
Old April 16th, 2015, 15:32   #4
bmwM5power
bmwM5power's Avatar
My '12 golf did this as well, I got tired explaining this to my dealer, traded it in and got manual instead. Not sure if its normal or not, but my 09 Jetta didn't do this
bmwM5power is offline   Reply With Quote
Old April 16th, 2015, 16:21   #5
skinnyb
Yes mine reverberates off the wall at a drive thru window or in a parking garage. I have however put mine in manual and it doesn't make it stop. It has done it since day 1 and hasn't gotten any worse so I'm going to drive it till it flies apart then I will know what to fix lol.
Old April 16th, 2015, 20:09   #6
evantful
Same thing, Ive had two DSG cars prior and neither did this. Not even close
Old April 17th, 2015, 10:37   #7
krebsy75
Our new '14 appears to make this sound. We picked her up last Saturday and noticed it in a parking garage. Our '12 never did this. Slightly disappointing but I'm not letting the dealer touch a brand new DSG. So far it's barely noticeable.
This thread has helped alleviate my concerns.
krebsy75 is offline   Reply With Quote
Old April 17th, 2015, 11:01   #8
evantful
Here is a better video of what it normally sounds like. This is outside the car, which is actually quieter than the noise when the windows are up inside. But the noise canceling on my phone kills the rattle inside. This is about 900-1200rpm
In this run it was little more on and off, normally once it starts rattling it doesn't stop until I come to a dead stop or bring it above 1300rpm.
https://www.youtube.com/watch?v=8A-i...ature=youtu.be
The reality for me is for the first 15k it never once did this, then suddenly it did, and seems to be getting very slowly worse. If I went to sell the car and someone heard this they most likely wouldn't consider buying it. Hell if I had ever heard this sound coming from it I wouldn't have bought it new.
Old April 17th, 2015, 13:12   #9
krebsy75
Ours isn't quite that obnoxious. It's much more subtle but similar in nature.
Old April 17th, 2015, 13:38   #10
krebsy75
It looks like your driveway represents the perfect scenario in order for this problem to occur.
Old April 17th, 2015, 16:26   #11
evantful
Yeah, normally the DSG's I have used in the past gives almost like a chugging rattle. The sound was pretty constant and consistent. It was never concerning.
This has a really hard metal banging, that changes rapidly in pitch. And mind you when you throw in the harsh vibration that starts with that noise, it creates a pretty unsettling situation.
Normally it happens in parking lots, drive throughs, toll booths whether under load or just coasting.
Old April 17th, 2015, 17:14   #12
krebsy75
Trust your instinct. Take it to another dealer if you have to.
06 dsg rattle when idling witmerj TDI 101 4 June 13th, 2012 09:13
How long on rattle DSG/DMF... benstdi TDI 101 2 December 14th, 2011 07:09
DSG DMF rattle, will the VW dealership know? turdlarsen TDI 101 11 October 18th, 2010 10:05
DMF on DSG changed now have a rattle Fireblade_rr VW MKV-A5 Golf/Jettas 3 August 23rd, 2010 23:44
DSG Rattle Stuart Eng VW MKV-A5 Golf/Jettas 16 June 7th, 2009 19:37
Page generated in 0.14394 seconds with 11 queries
[Output: 105.74 Kb. compressed to 88.98 Kb. by saving 16.76 Kb. (15.85%)]
