I put a TDI in a rabbit pu,from a 98 jetta (ahu)using the jetta trans etc.Best way is to find a donor car.I can pm some pics.Lots of work even for a VW tech.Ya I work at a dealer.
It has been done. Forum member Crewcabcaddie has done it. Do a username search here.
Also search over at vwvortex.com--lots of info--keywords: TDI, swap (oh yeah, make sure to check the archived posts box, as most of these posts are older)
Here's a TDI in a caddie (not the same one as I mentioned above):
That is a nice and respectable tdi conversion. I would like to do a conversion like that. Keep this post alive, if anybody has pics please add them in this post thanks.
