gotdiesel
03 Jetta auto. With cruise switch in on position and dash cruise light on, speed will not set at any speed. Could it be a problem with the brake pedal switch. I could understand it if the cruise would not kick off when you hit the brake but in this case it just will never set. No one has messed with the ECU but there was a glow plug light (has reset). Used an OBDII and there were no DTC's. Had the recall brake switch installed a couple of years ago.
