Old June 30th, 2020, 09:43   #1
lisab4
lisab4's Avatar
Question Instrument cluster problem
I installed a cluster Derek @ Chubbs auto made for me, TDI with MFA. Have a slight problem however.. the glow light stays on after starting. It's not on full power, about half dimmed. Thinking about a leak current somewhere or something? Any idea anyone? It is definitely the cluster as I tried the old one without MFA and it works perfectly.
Link to a Youtube film I made showing the problem:
http://youtu.be/hxJjkYyRCaU
1996 Passat B4 1.9TDI 1Z
lisab4 is offline   Reply With Quote
Old June 30th, 2020, 13:50   #2
BigAndy
TDI(s): 99 A3
Because the other cluster works - ie the glow plug light works properly and this cluster doesn't, I'd say the cluster has a defect.
The other issue, if both clusters have the 'dim' glow plug light, then I would swap out the glow plug relay.
On many long journeys have I gone. And waited, too, for others to return from journeys of their own. Some return; some are broken; some come back so different only their names remain.
BigAndy is offline   Reply With Quote
Instrument cluster problem shendlaw VW MKIV-A4 TDIs (VE and PD) 2 March 23rd, 2018 02:38
Instrument cluster problem mazzystr VW MKIV-A4 TDIs (VE and PD) 2 May 1st, 2016 10:35
Instrument Cluster removal, any problem with Immobilizer ? Ven99 VW MKIV-A4 TDIs (VE and PD) 2 June 28th, 2014 10:49
Instrument Cluster Swap Problem bgromacki TDI 101 9 May 3rd, 2013 11:30
Instrument cluster/No start problem, need help! Reifenberger TDI 101 4 October 15th, 2012 17:18
Page generated in 0.13831 seconds with 13 queries
[Output: 52.88 Kb. compressed to 48.76 Kb. by saving 4.12 Kb. (7.80%)]
