Old October 18th, 2019, 13:22   #1
AWD-TDI
Default Help me identify this turbo manifold
Not sure what this is...
MK4 TDI Jetta with 4 motion
VNT2052
Thoughts?
Thx
Sent from my SM-G973W using Tapatalk
AWD-TDI is offline   Reply With Quote
Old October 18th, 2019, 15:29   #2
mrchill
Super Secret Diesel Ninja Vendor
w/Business #
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Maybe an AAZ...interestingly, I have one of those in one of my many boxes of bits....came with a vnt 20 attached to it. As I recall it was an early vw diesel.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old October 18th, 2019, 15:34   #3
Yourbuddysatin
Fuel Economy: 32-35mpg
Does it have 3 bolts or four bolts holding the turbo on? BHW have 3 bolts for the turbo.
Yourbuddysatin is offline   Reply With Quote
Old October 18th, 2019, 22:20   #4
WarmStart
TDI(s): TDI
Looks like something like this.
https://forums.vwvortex.com/showthre...O-thermocouple
WarmStart is offline   Reply With Quote
Old October 19th, 2019, 04:44   #5
Yourbuddysatin
I’m just throwing this one out there but maybe it’s an older 8v 2.0 gas aftermarket turbo manifold.
Old October 22nd, 2019, 19:31   #6
AWD-TDI
4 bolts
Old October 22nd, 2019, 19:37   #7
AWD-TDI
Originally Posted by WarmStart View Post
Wow, think you just about nailed it but mine did not seem to need an adapter flange... my flange seems like 1pc with the holes per your attached image.
I see a spot where a TC could be mounted underneath before the turbo as well. I'm guessing that TC placement would be better than after the turbo too.
Old October 22nd, 2019, 19:40   #8
AWD-TDI
Iím just throwing this one out there but maybe itís an older 8v 2.0 gas aftermarket turbo manifold.
I'm not too sure about interchangeability on those two motors but it is a casting with Germany embossed. I'm guessing aftermarket manifolds are fabricated vs cast but could be wrong.
Old October 23rd, 2019, 13:52   #9
Chrislupo
Hi,
it seems like original VW.
I can not read all numbers but it starts with 05(8 or0)129 68..
Perhaps you can verify it.
Or I need a picture with another angle...
If I look longer on the picture it could be 058 129 68 .. A or 068 129 68 .. A
The other one are from Golf2 TD, should be 068 129 591 G
https://www.teilehaber.de/itm/auspuf...rc6724246.html
Chrislupo is offline   Reply With Quote
Old October 23rd, 2019, 18:52   #10
AWD-TDI
Originally Posted by Chrislupo View Post
Hi,
Good eye dude wow. Ya I think I can do something to bring the numbers out better
Old October 24th, 2019, 13:08   #11
Yucca
1.6TD manifold with adapter plate.
Yucca is offline   Reply With Quote
Old June 30th, 2020, 12:29   #12
AWD-TDI
Hey guys, gotta bring this one up again. I bought a BRM intake manifold and the darn thing wont fit because of how close the turbo is. I'd really like to run that unit as it is much nicer than factory ALH. Does anyone know of a manufacturer for an exhaust manifold spacer? I figure I need about 13mm
Old July 2nd, 2020, 14:31   #13
AWD-TDI
Well, figured out it would be best to just get a spacer for the turbo itself... T25 flange spacers are pretty cheap.
How to Identify Turbo on my 2002 Jetta drseth VW MKIV-A4 TDIs (VE and PD) 10 October 17th, 2014 13:14
Help me identify a turbo.... TDIJetta99 TDI Power Enhancements 5 June 13th, 2012 13:02
Help.. Identify this manifold beeman VW MKIV-A4 TDIs (VE and PD) 8 April 26th, 2012 19:12
Identify this Turbo Intake Pipe? May-39 TDI Power Enhancements 1 April 8th, 2012 06:48
How to identify turbo type/model? gazmantek TDI 101 2 January 2nd, 2008 05:32
Page generated in 0.17700 seconds with 13 queries
[Output: 112.20 Kb. compressed to 94.25 Kb. by saving 17.95 Kb. (15.99%)]
