Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi A3
Audi A3 Discussions area for Audi A3 TDI (2010+ in Canada & the US).
Old June 27th, 2020, 14:03   #1
iirviing
Default Where is a/c condenser drain plug?
Need to find out if it's what's causing my a/c to blow hot air when in traffic but cool air when on the highway. I checked the freon and it's good. Also have to check condenser next.
iirviing is offline   Reply With Quote
Old June 29th, 2020, 05:08   #2
Nekit
TDI(s): 2013 A3 TDI
I've heard some people mention the high pressure switch. Also have heard that their is a control switch/valve on the compressor that can go bad. I have had similar problem with random no A/C on my A3. Post if you find out what it is. Thanks
Nekit is offline   Reply With Quote
Old July 4th, 2020, 15:47   #3
QuickTD
Good cooling while moving but poor cooling standing still is a rad fan problem.
QuickTD is offline   Reply With Quote
AC condenser drain plug 2012 Passat tonyman VW Passat Family (NMS and B7) TDIs (2012+) 16 June 20th, 2017 20:23
Help with O2M part numbers (drain plug and inspection plug) slyk VW MKIV-A4 TDIs (VE and PD) 2 February 10th, 2017 17:37
Drain plug? oldiesel TDI 101 2 September 27th, 2005 16:54
Drain Plug whizbyu VW B5 Passat TDIs 4 January 15th, 2005 11:43
fumoto drain valve and bypass return to drain plug oldpoopie Fuels & Lubricants 1 September 17th, 2001 11:48
Page generated in 0.11663 seconds with 13 queries
[Output: 56.26 Kb. compressed to 51.15 Kb. by saving 5.12 Kb. (9.10%)]
