lee157
OK as per my last post I have identified the Turbo Actuator (left green circle) and now I have questions,,,,
I checked this with engine off,, I pulled the hose that goes to it from the valve on the right (see pic) and the actuator DOES NOT HOLD ANY VACUUM like you are sucking on an open hose
BUT I can NOT blow into the hose at all,,, maybe a check valve some place??
Could all the wires going into this thing control some solenoid that would NOT let it hold vacuum when not running????
OR is this thing shot??
I'm pulling this code consistently 000665 - Boost Pressure Regulation: Control Range Not Reached P0299 and fighting limp mode periodically.
