I have an issue with my 96 TDI Passat. When I turn the wheel slightly (as in 15-20 degree angle) to the left, the car starts to choke and gasp like it isn't getting any fuel. When I turn it back to the right, it straightens up.
I recently replace the ECM since it was doing the choking/gasping thing all the time and the only way to fix it was to unhook the battery cables and let it sit for about 10 minutes. When everything was hooked back up, it could run for about a week without any issues. That part was diagnosed as a capacitance discharge issue and replacing the ECM was the only way to fix that.
Someone suggested that it might be the "clockspring", since in some cars they control/influence a lot of things. I don't even know if there is a clockspring so I thought it was worth asking.
