Penaran561
My driver's door is not opening when I unlock. All other doors unlock. Only time it opens is after I start the car. Sometimes the door doesn't open from the inside even if the car is running. What could be the problem?
This is a known problem with Passats of this vintage, or at least it was when it happened to mine. IIRC, there is/was a recall on this issue, or at least at TSB. I cannot recall whether it was repaired under the car's warranty or under the recall.My driver's door is not opening when I unlock. All other doors unlock. Only time it opens is after I start the car. Sometimes the door doesn't open from the inside even if the car is running. What could be the problem?
