jimbo1mcm
- Joined
- Jan 5, 2015
- Location
- CT USA
- TDI
- 2015 SEL TDI PREMIUM Blue 2015 SEL TDI PREMIUM's Silver and Blue
Fired up the VCDS: No faults. Printed it out. Took some photos of my work. I want a record in case of warranty issues later. Put it up on my ramps.Used my Oil Evacuator and got most of the oil out, then went under removed the belly pan.( T25 for side ones and front one and t40 for the 3 back ones. Make sure you depress the two plastic tabs in the front to remove the pan. I was going to pull the drain plug, but I noticed that the Mahle filters I got did not have a drain plug gasket, so I just left the plug in. I'll get it next time. Used the special tool to undo the filter. Just a little came out, about 1/4 of a pint. Installed new filter, torqued it to specs,( 25nm) ran the engine to check for leaks and put the pan back on.
Changed the fuel filter. I put a lot of paper underneath the filter in case I spilled some and just a little came out. Used a bungy to hold the filter top off so I could remove the filter. I put the new filter in slowly and let it soak in, then added diesel fuel to the outside edges of the filter. Filled it to the top and put the screws back in. Torqued them to 5nm using cross pattern. Be careful removing and putting the screws back in. If you drop one you have to drop the pan and go look for it. You might be dead in the water if you lose one until you get another one because the filter probably won't seal with only 4 screws. Engine started up right away.
Added DEF using the MB hose and 5 gallon jug. Not a drop spilled.
I'll do the tires later. Took about 2 1/2 hours because I went slow and was smoking a cigar.( carefully )
Re-set VCDS for next inspection. I change the oil at 5,000 filter at 10,000. Used the VW Castrol.
