gcodori
- Joined
- Mar 16, 2005
- Location
- northern california (bay area)
- TDI
- 2001 NB TDI plus CPO 2013 Passat TDI SEL Prem.
I plan on doing the DSG service soon, in my driveway.
This driveway slopes down from the garage door to the street, so if I park normally, the nose of the car is higher than the rear. Conversely, if I back in, my front is lower than the rear. It's not extremely steep, but maybe a rise of 6-12 inches over the length of the car.
When I change the oil, I back in and then jack up the front and use stands in an attempt to get as level as possible. So far this hasn't been an issue, as I slide in under the front which is raised while the rear sits on the ground. Does this make sense?
My concern with the dsg service is the problems that can arise if the car is not completely level, either front to back or left to right (the street also has a slight slope down from drivers to passenger side if backed in).
I understand that making it level ensures the most complete draining and leveling of the fluid. I plan on doing the measure and top fill method. With the oil I see this as a bigger issue as the drain plug is on the SIDE of the pan, making the draining more picky due to the slope.
With the drain on the BOTTOM of the DSG, does this seem like a good idea? Are people really shimming the stands in order to get complete perfect level-ness?
