Yankinwaoz
I live in a condo in California. I have emergency survival basics stored that will allow us to cope with no food, water, power, shelter for a few days.
I don't have a generator. And I don't want one. They are big. I have no place to store it. I don't want to store gasoline for it. And when they run, they are noisy.
I'm prepared to survive without power for a week. But, it would be nice to be able to get some power to ease things. So I was thinking about getting an inverter.
My carport is steps away from my condo, and I even if the carport fell down in a large quake I could clear it away.
The idea is that I could bolt a 1500 watt inverter to the battery posts of my Passat. Then run the car for 2 to 3 hours a day to power the fridge and top up batteries. This assumes that I can run an extension cord to the fridge, and that I can get to it. More than likely I will be able to.
I figure that letting it run 2-3 hours a day, and not opening the fridge door very often, will allow us to preserve food longer. Make life a little easier.
The inverter is small so I could store it in the emergency box. It can put out 1500 watts, which is more than enough to handle the spike when the compressor turns on. And I think my fridge can handle a modified sine AC, versus the pure sine it normally gets from the power company. Worse case I burn out the fridge motor prematurely. Least of my worries in a disaster of that scale.
http://www.theinverterstore.com/2000-watt-power-inverter.html
Here is the problem, or worry. Can the alternator handle it? The car battery should be able to absorb the spikes from the compressor motor. But if VW only made the alternator strong enough to run the motor, lights, stereo, and keep the battery topped up, then can it handle the additional load of up to 12.5 amps drawing on it?
It would really suck in my mind to have this nice life-safer for the condo, then when I need to use the car after the disaster, it won't run because I've fried the alternator.
Thoughts?
Thank you
Thoughts?
Thank you
