jmarvin
Does anybody know if the MKIV requires a subframe alignment? Was under the car looking for the alignment holes that VW tool 3393 fits into and couldn't locate them.
IIRC you drop the car so the wheels are on the ground and all the linkages snug. X ft-lbs + 90 degrees.Does anybody know if the MKIV requires a subframe alignment? Was under the car looking for the alignment holes that VW tool 3393 fits into and couldn't locate them.
