If by "direct drive" you mean the wheels and the engine are turning at the same speed, that's not addressing what I said about the differential - it's just a final drive ratio of 1:1.
You still have an open differential in there (which is why when you go around turns in 4th gear, the inside tire doesn't scrub/chirp).
The only ways I can see the stock transmission working to drive a generator:
1. Two independent, equal-sized generators, one attached to each output. Downside: if the load isn't perfectly balanced at all times, the moment one gets more load it will immediately stop spinning and all drive goes to the other (and your diff probably explodes), like sitting with ice under only one tire.
2. Replace differential unit with a "spool", eliminating the differential function completely.
3. Same as #2, but via "Lincoln Locker" (stock differential with all its internal parts welded together). "Lincoln" as in "Lincoln Electric Welding"...
Still using the trans in the car to do this doesn't seem like the best idea. Someone here (think it was N1DAS) once found an ALH or ALH-like engine powering a generator at a cell phone tower years ago - there's a thread around here somewhere about it. If you really want to repurpose your engine for generating, maybe try to track down one of those for the the conversion parts.
