charlieruu
I'm definitely buying a tune but I haven't decided which to get. Should I save the extra 100 and get the kerma or a stage 1 malone?
Not to be an A**, but if you want to save money - don't get a tune at all and save $3-400. Now, if you want to get more power out of your car - get a tune.I'm definitely buying a tune but I haven't decided which to get. Should I save the extra 100 and get the kerma or a stage 1 malone?
Its an auto and I honestly have no idea what that isIs your car manual or auto? Have you already or do you plan on deleting the DPF?
Did you respond? What do you think could be wrong about the mileage?I just saw your thread in the fuel economy section, before getting a tune you should get your car running properly. Something is wrong at 300-350 miles/tank, my 14 gallon gasser does that tank after tank.
I don't have a Malone stage 3, but my stage 2 tunes (I have loaders) on BOTH my cars are absolutely rock solid and are doing exactly what I got them to do. I'm not a long-time veteran here/with TDIs, but I have read quite a bit and I've yet to read about anyone having a problem with a Malone stage 3 such as you had. Not saying that I don't believe it, it's just that I'd figure that there was/is something else going on. My understanding is the the Malone tunes are more canned than are those from Kerma: I'd really like to test out a Kerma tune- I kind of have an offer to do so but haven't been able to connect on this yet. So, being "canned" would suggest that it would tend to be more of an issue with the car rather than the tune itself. Higher, more customized Malone tunes are/would be different, though here, as with Kerma and most other tuners, pretty much come with support to work through getting the tunes dialed in for the particular car.I ran the Malone stage 3 for over a year but I had boost issues that never seemed to go away. The car ran fine but I could not get the boost to stabilize it would always wander like a lost dog. Replaced n75, checked stop screw, vacuum tested actuator, replaced all vacuum lines, etc...
Paul made me a good deal so I switched over to Kerma and the boost control is rock solid now. The Malone tune ran fine but the Kerma tune seems to make a little more power and it keeps the gauges doing what they are supposed to.
If you had a close local dealer to work with that would probably be best. If you don't then Charlie (Kerma tuning) is very easy to work with and he will get updates to you very quickly so you can upload yourself. I prefer to save time and do it myself with the Q loader.
I was thanks, meant to throw the quote up in there.I believe Kier was responding to eecsentric's question.
