Old June 11th, 2018, 12:04   #16
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
DD with such a big turbo? wow, waiting or 3000rpm for the turbo to start spooling must be fun on a 5000rpm diesel
Imagine going with 3-4 passengers into a mountain ride, you have to pull 3rd gear because in 4th it dies. Not funny
Imo after changing a few turbos, the perfect choice remains the stock 2260 or latest 2060 since they have stock engines-fueling.
What good is it that i burn smokeless 130+ mg of fuel after 3500rpm but its dead under, useles..
CP3 Upgrade
100-200 Acceleration
Macradiators.com is online now   Reply With Quote
Old June 11th, 2018, 12:39   #17
diffas
diffas's Avatar
Well. Wider your revband and you wont be struggeling. Just wondering how they can run gasoline engines at all when they spooling so late... Imagine some wonderful wonderbox where you can choose where you are on the revband. I wish all can afford it in some day
diffas is offline   Reply With Quote
Old June 11th, 2018, 12:53   #18
Macradiators.com
You just can not pull 5500rpm on a 380+ diesel with family in the car ..way too loud.
Thats why i would go with stock size turbo for daily cars.
CP3 Upgrade
Old June 11th, 2018, 12:56   #19
diffas
diffas's Avatar
I've heard some kind of magic things where loud sound goes in and not so loud sound comes out. What those might be?
Old June 11th, 2018, 13:11   #20
Macradiators.com
Yeah, i bought a 3 chamber flowmaster deltaflow series 50 from usa, need to install it. maybe it makes a difference.
CP3 Upgrade
Old June 13th, 2018, 18:42   #21
sltlytwkd
TDI(s): 03 jetta
Fuel Economy: 39
I made 209hp with my 1756vk, it did push a lot of oil too though. Stock everything but injectors, studs, and fmic. Swapped it for a 2260vk, barely can tell the difference in spool but wayyyy more top end pull where the 1756 flatlined. I wish I never even bothered with the 1756, I love the 2260!
03' jetta on 18s, race 520s, gtb1756, fmic, 3" exhaust, 6" tip, fmj panzer plate, Malone stg 5, neuspeed sway bars
sltlytwkd is offline   Reply With Quote
Old June 13th, 2018, 20:47   #22
travis45
travis45's Avatar
Luxemburg, heck we're neighbors! I'm just south of Green Bay in Wrightstown.
14 Sportwagen GTB2260vklr Turbo, Rawtek turbo back exhaust, Malone custom tune, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, KW V3 Coilovers, H&R 22mm rear sway bar, PolarFIS, Darkside intercooler and piping, Wavetrac LSD. Soon to install Colt billet stage 3 cams w/upgraded springs, ARP Headstuds.
travis45 is online now   Reply With Quote
Old June 13th, 2018, 21:08   #23
3L3M3NT
3L3M3NT's Avatar
Now you have me re-thinking my idea to go with a GTB1756VK or GTD1752VRK... I might have to go up a size.
Sturgeon Bay here and I'm hosting a cruise/gtg on October 20th, so why don't we all have some fun cruising the back roads of Door County and then have a cookout and BS about our cars. Now get moving on your car Travis, so we can check it out this fall.
Cruise/GTG
Sturgeon Bay, WI Cruise/GTG October 20th, 2018
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
3L3M3NT is online now   Reply With Quote
Old June 14th, 2018, 03:18   #24
jetta_mkV
jetta_mkV's Avatar
Fuel Economy: 4.6L/100km
Hey all, I've been using a 2060vklr for almost 5 years now and for just over 1 year I've upgraded it with a billet compressor wheel. I've had no issues running 40psi through it (before and after the billet wheel) and no oil leaks... apart from when it was touched by another workshop who stuffed it all up and I ended up fixing it again...
My 2060vklr has been welded onto the stock cast manifold too. I couldn't be happier with this turbo. In my opinion it's worth every cent! If you're interested in such a turbo, get in touch with JTT. I bought mine off him.
Sent from my Pixel 2 XL using Tapatalk
Jetta MK5 TDI-R AWD 07' 2.0 16V BKD 6speed manual, GTB2060VKLR with billet comp wheel running 40psi, custom full exhaust 2.5", custom tune, EGR delete, uprated S3 intercooler, AMC head, custom 2.5" alloy IC piping, 4Bar MAP sensor, Clutchmasters organic SMF clutch kit, Fluidampr pulley, AWD converted, TTRS front brake kit, etc.
jetta_mkV is offline   Reply With Quote
Old June 14th, 2018, 11:16   #25
travis45
travis45's Avatar
Cruise/GTG
Cool, I'll will put that on the calendar. Hopefully my car should be all put back together and tuned properly by the....
Old June 15th, 2018, 06:00   #26
sltlytwkd
TDI(s): 03 jetta
Fuel Economy: 39
[QUOTE=3L3M3NT;5416066]Now you have me re-thinking my idea to go with a GTB1756VK or GTD1752VRK... I might have to go up a size.
Your buddy Jfettig that I met at your cruise a few years ago did the tuning for me. So a huge shout out to him for fondling it to my liking!
Old June 15th, 2018, 21:56   #27
3L3M3NT
3L3M3NT's Avatar
Yeah, Jon does a great job on working with people to get them exactly what they want.
He spent quite a bit of time dialing in my car when it was getting some work done on it by greengeeker. The car runs amazing now and is a blast out on the track. What better way to put a GTB2260VK to good use.
Firefox fix
RTDI Build Thread
Old June 15th, 2018, 23:32   #28
TheoSweden
TheoSweden's Avatar
TDI(s): A3Q,A4Q
No problems with 2260VKLR here! They are designed to last 1 000 000km, so if the installation isnt done bad there should be no issues.
I use no oil restrictor!
TDI Project: VW Golf 1 - 83
Track/Ice racer: Audi A3 TDI Q - 02 ~280hp
Daily driver: Audi A4 TDI Q - 08 ~300hp
http://65.110.12.166/showthread.php?t=378371
TheoSweden is offline   Reply With Quote
Old June 16th, 2018, 00:08   #29
Macradiators.com
The tw i use is different from stock and that might be the issue.
CP3 Upgrade
Old June 16th, 2018, 01:38   #30
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
That's exactly the issue - I know the pain well
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
3.0TDI S200v hybrid (470hp) kit for sale
http://forums.tdiclub.com/showthread.php?t=492614
Bobby Singh is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ErackTDI
Fun build just need to pick a turbo. miatamike203 TDI Power Enhancements 48 December 31st, 2016 20:23
New Turbo: Help Me Pick One storx TDI Power Enhancements 60 March 3rd, 2014 09:07
Pick my turbo Diesean TDI Power Enhancements 6 October 2nd, 2013 17:31
FS: VNT-15 Turbo Pick-up only Sebpt Ontario 1 April 27th, 2009 12:26
faint turbo but great pick up ljnoel TDI 101 20 May 8th, 2008 10:12
Page generated in 0.17082 seconds with 11 queries
[Output: 135.00 Kb. compressed to 112.70 Kb. by saving 22.29 Kb. (16.51%)]
