Old May 26th, 2018, 10:04   #1
WarmStart
TDI(s): TDI
Default 1.9 TDI 81kw no power, all measurements OK.
Hello.
I have lack of power on my 1.9 TDI 81 kw. It's not limp mode but car are not moving as it should.
I have been driving this car more than 100 000 km. Had always been lack off power. Weird is that in some time (rarely) in second gear car accelerate as it should. And after a long trip towing heavy trailer car has more power than regularly but not long time.
I have check all mechanical thing what I can think and use ross-tech, all measurements are as they have to be, even the fuel quantity when accelerating is 44.4 (or similar) mg/stroke.
How ecu knows injected fuel quantity?
WarmStart is offline   Reply With Quote
Old May 26th, 2018, 21:09   #2
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Check for a leaking boost hose.
Old May 27th, 2018, 03:44   #3
WarmStart
TDI(s): TDI
I have checked boost and vacuum leaks more than three times last few years, no leaks. All vacuum solenoids have been cleaned and work good, good vacuum.
New turbo, adjusted as it's have to be.
Compared MAP with mechanical gauge.
New MAF.
I replace fuel filter at least once a year.
There are no black smoke behind the car (NEVER)! ECU is saying to the VCDS that there is fuel but actually there is not so much fuel as it should be.
Where does the ECU get info for the fueling?
Is she using needle lift sensor for that?
Or is she using map for that, ECU is saying to the Quantity Adjuster how much to move and the calculate fuel quantity, but Actually ECU does not see how much fuel there is?
Old May 28th, 2018, 01:53   #4
duke21
TDI(s): 2.0 TDI BMN
Fuel Economy: 7.0L/100km
Same problem like i had always with my PPD170. I bet its something fuel related...
duke21 is offline   Reply With Quote
Old May 28th, 2018, 09:40   #5
Yourbuddysatin
What tdi are you working with?
Yourbuddysatin is offline   Reply With Quote
Old May 28th, 2018, 10:41   #6
Kerma_tuned
Fuel Economy: 51
Check the intake and make sure its not carnoned up? Over half the intake on my tdi was restricted because of carbon build up and made it feel like there was a lack of power
Kerma_tuned is offline   Reply With Quote
Old May 28th, 2018, 11:20   #7
WarmStart
TDI(s): TDI
I have 2004 Seat Leon with 1.9 TDI 81 kw engine.
I cleaned the intake and closed egr valve with metal plate.
That kind lack of power is quite "normal" with those older TDI-s.
I find a post where is information what I need: http://forums.tdiclub.com/showthread.php?t=339804
And little bit more:
http://forums.tdiclub.com/showthread...=350382&page=2
I think there are metal in the pump.
I'm gonna take pump apart and clean everything, let you know if it solves my problem.
Old May 28th, 2018, 17:44   #8
Yourbuddysatin
So is that a VE engine or PD? Not sure what years has what in those over seas....
Old May 28th, 2018, 22:41   #9
WarmStart
TDI(s): TDI
It is VE pump.
Old May 29th, 2018, 09:18   #10
Yourbuddysatin
Have you checked what the map sensor is measuring?
Old May 29th, 2018, 13:19   #11
WarmStart
TDI(s): TDI
Yes I have compared VCDS shown reading with manual pressure gauge, map sensor is showing accurate numbers.
Old May 29th, 2018, 14:03   #12
Yourbuddysatin
I could be wrong but what I’ve always thought is if you have boost you have fuel. So maybe you have a bent connecting rod or something to bleed the cylinder pressure? Kinda odd to me that you can make the correct boost but not have power?
Old May 30th, 2018, 11:23   #13
WarmStart
TDI(s): TDI
I taked apart the injector pump electronics and cleaned all the metal.
No difference!
I found in VCDS where I can check Quantity Adjuster voltage to the ECU.
min. -0.6...v
max.- 4.6...v
full throttle when accelerating.- 3.6..v
(some months ago I tried my friend car MAF. And compared reading with my own car MAF, reading was quite similars. Then I disconnected MAF and made same accelerations and then I reconnected the MAF (engine running) then car was acting like it should, tire spin in a second gear on a tarmac. MAF readings was exactly the same when car was not moving correctly.)
Old May 31st, 2018, 06:54   #14
Yourbuddysatin
I’m at a loss. Sounds very strange.
Old May 31st, 2018, 07:47   #15
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
Group 15, what Actual et Request value at WOT?
Group 10, what intake pressure at WOT and 3000-4000rpm?
Group 13, what value, engine >70celcius and idle, no light or AC.
Group 4, What actual and specified start? (cold engine)
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Audi A6 1.9TDi '98 81kW poor power until 3 krpm [Video] [VAGCom Log] Arturasz TDI 101 2 October 5th, 2012 06:37
Low power on 1.9 TDI AHF 81kW cidades VW MKIV-A4 TDIs (VE and PD) 1 September 18th, 2011 15:39
108HP (81kw) Tdi Ben-Zion Petersen TDI 101 0 October 10th, 2006 08:41
B5 TDI 81kW 1997 voerboer Passat TDI Picture Gallery 4 March 15th, 2001 00:20
97 TDI 81KW Power Lack & high noises Oliver lahr VW MKIV-A4 TDIs (VE and PD) 3 October 22nd, 2000 17:55
Page generated in 0.18087 seconds with 11 queries
[Output: 119.65 Kb. compressed to 99.57 Kb. by saving 20.08 Kb. (16.78%)]
