Old June 9th, 2018, 08:50   #1
smbaau
Default exhaust manifold identification
good morning,
2003 jetta wagon, tdi, 220,000 miles
doing a intake cleaning along with some EGR refinement .
i am adding a pyrometer and i noticed most the recommended location
is between the r's on the cast in Garrett on the exhaust manifold . mine does not
have garrett cast into the manifold, it has the number 2211-1 cast in and
there are some audi circles on the driver side.
any idea what manifold this is?
thanks in advance for any help or suggestions
smbaau is offline   Reply With Quote
Old June 11th, 2018, 16:07   #2
smbaau
Default Exhaust I.D.
I think i found it, the exhaust manifold in the picture on this link has the
same numbers, under $400 dollars, anybody have any experience with
this unit? is it a ticking time bomb?
https://www.buyautoparts.com/buynow/...hoCBPAQAvD_BwE
thanks Craig
Old June 11th, 2018, 18:20   #3
Nevada_TDI
Craig, I am confused. The link goes to a complete turbo, not just an intake manifold. With the manifold off a better place to drill is at the inlet of the turbo down on the side of the manifold.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Previous Diesel: 1983 Rabbit Diesel
Old June 11th, 2018, 21:02   #4
smbaau
hello Nevada ,
i took off the intake for a cleaning, and it needed it badly, i drilled and mounted
the exhaust manifold for a pyrometer. i was expecting the exhaust manifold to have Garrett cast into it, but it looks like am non-OEM exhaust manifold and turbo. i am worried that this may be a poor quality off brand unit.
the Car is running very good , feels like a totaly different car.
thanks for replying, and have a good evening
Old June 12th, 2018, 04:07   #5
oilhammer's Avatar
Fuel Economy: fantastic
Except for a couple months of very early 1998 ALHs (that all blew up right away), all ALHs sold here have a Garrett turbo from the factory.
The word "Garrett" will be in the aluminum compressor housing, and there will be a little blue printed metal tag also on that housing.
www.cardocautomotive.com
Old June 18th, 2018, 08:01   #6
[486]
TDI(s): 02 golf ALH
I've always stuck the probe in the runner from cyl 4, just about even with #3 pointed straight back
just seemed the most convenient location at the time.
1 and 4 are the hot cylinders anyways due to intake manifold design, may as well get the 'worst case' EGT number
(WTB) PD 130 intake manifold, egr delete, AAZ 3-bolt exhaust manifold joelsolomonson Private TDI Items for Sale/Wanted 2 August 26th, 2016 15:48
F/S : 1.9 TDi inlet manifold and exhaust manifold Jaco Private TDI Items for Sale/Wanted 0 April 8th, 2015 06:51
MKVI (MK6) Exhaust Part Identification (easy one here) evolDiesel TDI Power Enhancements 2 March 22nd, 2013 18:03
exhaust manifold Q bencarr23 TDI Power Enhancements 38 May 19th, 2006 12:31
Page generated in 0.14694 seconds with 13 queries
[Output: 73.88 Kb. compressed to 64.79 Kb. by saving 9.09 Kb. (12.30%)]
