KillyMcGee
2001 TDI M5
Lets not go heavy into the "you should have" and "why didn't you check this before buying" part of the ordeal.
I own the car now and want to make as good of a situation out of what looks like a crappy one.
The car ran great when it was warm. Now it won't start unless the engine is warmed up, or unless the coolant sensor is unplugged and you wait ~10 seconds before cranking. Outside temp is 60-70 degree F. No smoke when starting, idles fine. The pump is excessively loud, i do have another pump and rebuild kit. I do not have VCDS software though.
How likely is it that my compression is down or could it be some other issue that doesn't involve me having to do an engine rebuild?
Thanks in advance.
Thanks in advance.
