Can anybody explain why the injector wiring looms on modern TDI's cause problems?
The reason i ask is because i removed mine after VAGVOM/VCDS came up with the following......
1 Fault Found:
18074 - PD Unit Injector; Cylinder 1 (N240): Electrical Malfunction
P1666 - 35-00 - -
Closer inspection of the wiring doesn't appear to show any damage.Resistance check also appears fine.
Thanks in advance
djl
1 Fault Found:
P1666 - 35-00 - -
Thanks in advance
djl
