Dodgevillediesel
Wondering if injectors from an automatic trans alh will work on a manual trans alh.
I would tell you DLC 520 using a standard flow setting (Stage 1) this will get you the best fuel economy, lowest smoke and is 100% plug and play. Do keep in mind that the IQ and timing will need a mild tweak, but I have those instructions on our website to walk you thru the process.So if i send them out to get new manual nozzles they should work in my 5speed?
