Old August 26th, 2017, 20:12   #286
gassprint1
TDI(s): 2006 jetta
i changed the valve on my compressor today and the ac still doesn't work. fans don't kick on either. my buddys shop had a snapon scanner that does alot. we ran a test on the fans and the main fan kicked on with the test. small one didn't. low pressure was high and high pressure was low. there is power at the valve on the compresser, fan module too. any ideas.
gassprint1 is offline   Reply With Quote
Old August 26th, 2017, 23:01   #287
Sky King
Sky King's Avatar
Fuel Economy: Under 40 with the Cam upgrade and Malone Tune
Exceptional thread on the subject !!
http://forums.tdiclub.com/showthread.php?t=242699
Cheers,
Gene
2006 Beetle TDI
Sky King is offline   Reply With Quote
Old August 27th, 2017, 08:23   #288
gassprint1
TDI(s): 2006 jetta
yea read all the. mine don't kick on when supposed to and even when doing 70mph down the road, still no ac.
Old August 28th, 2017, 04:01   #289
Rx7145
TDI(s): 2006 Jetta
Sounds like the compressor is bad.
Rx7145 is offline   Reply With Quote
Old August 29th, 2017, 09:57   #290
DanG144
Sky King and others, that thread you referenced is for MK IV cars, not MK V and later. It is of no to the guys in this thread.
DanG144 is offline   Reply With Quote
Old August 29th, 2017, 10:02   #291
DanG144
I would use a VCDS to check the codes and information on the compressor.
This thread may help, it IS for Mk V and later cars.
http://forums.tdiclub.com/showthread...ompressor+shut
Old August 29th, 2017, 10:07   #292
gassprint1
TDI(s): 2006 jetta
yea i keep getting told that. working on getting the ross tech i think this week.
Old August 29th, 2017, 10:15   #293
DanG144
You might be able to find one locally to borrow.
Search for VCDS share or VAG-COM share database on line.
Old August 29th, 2017, 10:29   #294
gassprint1
TDI(s): 2006 jetta
Checked into that with no luck. Trying to order one today. Money is very very tight so guna have to do one thing an be behijd on another. Does get annoying being told the same thing all the time on Facebook. Hell even had someone tell me they only let their friends use the vcds
Old August 29th, 2017, 11:31   #295
DanG144
I have loaned mine out to strangers, locally, and mailed it to others, but usually I have known them (even just on the site) for a while.
There is a learning curve for using VCDS, as well.
But with Dodge, Chevy, and Toyota, no comparable tool is available at all in the less than $500 range (at least that has been my experience.)
Old August 29th, 2017, 12:04   #296
gassprint1
TDI(s): 2006 jetta
Just ordered one from idparts. 5%off doesn't work with rosstech. idparts said they can't sell it for less than what rosstech say is why no 5%off. but i did get the $4.95 3 day shipping which makes up for it... i got alot to learn when i get it. lots of what does this code mean type things....also just stumbed across someone on my facebook group that is from michigan and comes down where i am on weekends...things are kinda working out......
Old August 29th, 2017, 12:12   #297
jagster936
It's an invaluable tool if you plan to keep tdis around
2002 Silver Golf TDI, 5sp., 117k miles, dynoed 163 WHP, VNT17 turbo, Malone Stg 4, PP764 Injectors, 3bar MAP, SB stg.2 clutch - by AARodriguez
jagster936 is offline   Reply With Quote
Old August 29th, 2017, 12:38   #298
gassprint1
TDI(s): 2006 jetta
we'll see if i get everything fixed now, if i get another 80k out of it without something else going wrong.
Page generated in 0.14994 seconds with 11 queries
[Output: 105.97 Kb. compressed to 88.35 Kb. by saving 17.62 Kb. (16.62%)]
