Old August 27th, 2014, 09:32   #1
DubFamily
Fuel Economy: It's still a diesel!
Default Real-World Testing: Round 2
Greetings all!
Back again; with the release of Opti-Lube XL I decided I wanted to get some of it, since it seems to be the best lubrication for diesel currently out there. As I was getting some anyway, I decided I would do another round of testing with this.
I am not going to go through my testing procedures again, you can find them in the first 3 posts here if you want a refresher: http://forums.tdiclub.com/showthread.php?t=383811, this round of testing I'll be doing 1 tank each of Opti-Lube XPD, Opti-Lube XL, Power Service Diesel Kleen, and a tank of straight diesel for comparison.
The one thing I've changed for this round is this: Last time I knew what product was in each bottle... So this time I've provided the materials to a friend of mine, who is also a diesel enthusiast (trucks), and asked him to provide me the bottles prepared to add to my tank but without knowing what is in each.
About two weeks ago I received my gallon of XL; and a few days ago I provided this to my friend:
The diesel is to top off each bottle so no guesses as to dosage can be made either. He just put the correct dose rate for 15 gallons in each bottle. However, yesterday he told me he had prepared the bottles, but because the bottles I provided were clear, the differences between each bottle were obvious... So I gave him 4 XPD 8 ounce bottles instead, and today I received this:
So I'll be starting "A" with my next tank of fuel, and we'll see what happens.
-Jason G
Originally Posted by kjclow View Post
Dub said it better.
2014 BMW 328d xDrive
Member SSBMWO
DubFamily is offline   Reply With Quote
Old August 27th, 2014, 09:41   #2
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
looking forward to seeing your results. Thanks for taking this on.
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old August 27th, 2014, 09:59   #3
Cogen Man
Cogen Man's Avatar
Fuel Economy: Better than the Toyota FJCruiser
Also anticipating the results Jason. You the man.
I've gone from XPD to Diesel Kleen. Liked the XPD just too hard to get.
Cogen Man is offline   Reply With Quote
Old August 27th, 2014, 10:44   #4
ISurvivedNMU
Should be interesting as the weather is cold in the morning and warm in the afternoon, so a good mix for driving and testing.
ISurvivedNMU is offline   Reply With Quote
Old August 27th, 2014, 14:09   #5
14tdipassat
Subscribed!
14tdipassat is offline   Reply With Quote
Old August 27th, 2014, 14:39   #6
tikal
Fuel Economy: 37 MPG (~ 45% city)
I really like the process approach of this round two of testing. A little bit more scientific I would say. It might take a little bit of the placebo effect out or balance it across the trials. I have not tried any of the Opti-Lube additives yet but I am in conversation with some TDI drivers to see if they would like to do a group buy (probably XL flavor).
I will curious to learn if the driver can tell the difference in terms of 'feel' of the car or sound of the engine.
Thank you very much Jason for the effort!
tikal is offline   Reply With Quote
Old August 28th, 2014, 03:42   #7
Conrad -JSW
Conrad -JSW's Avatar
TDI(s): 2012 JSW DSG
Well done Jason! I'm looking forward to finding out what's what.
Conrad -JSW is offline   Reply With Quote
Old August 28th, 2014, 07:39   #8
Sigforty
What dosage rate for XL will you be using? Are you going to dose at the recommended and say one closer to XPD? I noticed in the Opti-Lube XL testing they did two dosage rates.
Sigforty is offline   Reply With Quote
Old August 28th, 2014, 07:47   #9
DubFamily
Each bottle has the dose rate for 15 gallons of diesel. It isn't 100% accurate for my tank size, but it is the closest easy measurement and I tend to run mine as low as I can so it should be close to that.
-Jason G
Dub said it better.
Member SSBMWO
Old August 28th, 2014, 14:20   #10
Sigforty
You may want to later try the increased dose rate for the XL.
Old September 2nd, 2014, 07:59   #11
DubFamily
After my first round of testing where I did a double dose test on 3 additives, I don't think it will really do anything different,.
FYI all bottle A goes in today; I have ~10miles to empty and can hopefully make it to the station before I run out...
-Jason G
Dub said it better.
Member SSBMWO
Old September 2nd, 2014, 08:35   #12
ize
TDI(s): 2010 Touareg
Watching.. for science
ize is offline   Reply With Quote
Old September 9th, 2014, 06:10   #13
ISurvivedNMU
It was cold this morning and I thought about this test. How is it going and can you get through it before the weather effects it?
Old September 9th, 2014, 08:29   #14
DubFamily
I apologize for the delay folks; I've just started back to school to complete my Masters and I am trying to get back into it, so time has been tight...
Weather is holding pretty steady overall so far; I am done with bottle A, bottle B is in. Planned to report this today:
Bottle A: 567 miles, 14.072 gallons, 40.29 mpg
It was a little cool this morning, but I don't think overall it will be a big hit. Due to the length of my drive overall temperature doesn't seem have much effect until it drops below about 40 degrees.
-Jason G
Dub said it better.
Member SSBMWO
Old September 9th, 2014, 09:11   #15
993er
993er's Avatar
TDI(s): None
What exactly are you testing and what do you expect to achieve in short-term testing?
Alex
993er is offline   Reply With Quote
Round the World in a VW Caddy LRTDI General VW Discussion 0 March 22nd, 2010 21:42
Hydrogen Injection. Any scientific debunking or real world testing? Hvatum Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 12 May 19th, 2008 06:18
The Steering Wheel of the Car Goes Round and Round, Round and Round Haiku TDI Eastern USA 342 February 13th, 2007 06:06
The Steering Wheel of the Car Goes Round and Round, Round and Round (x-post) Haiku TDI TDI 101 0 January 21st, 2007 14:42
Guinness Round-Britain World Economy Record. chopchop TDI Fuel Economy 4 July 6th, 2001 05:33
Page generated in 0.17340 seconds with 11 queries
[Output: 129.55 Kb. compressed to 107.92 Kb. by saving 21.62 Kb. (16.69%)]
