Jackbear
My stock 96 Passat wagon with a 1Z engine and stock tires, rims and no mods seems to be stuck on getting 44 mpg on a 2500 mile road trip around the desert southwest I took last week.
The engine has 6K miles on it but everything else is around 140K miles including the turbocharger.
I did all the recommended stuff like clean the intercooler loop, air supply system, etc.
It has a new MAF and N75 soleniod & 900 relay and is using Redline Synthetic 10-50 oil in the engine and Redline lube oil in the trans.
Clutch is new.
No Vag-Com fault codes before or after the trip either.
Point is regardless of me going 80 mph across Arizona for hours or leasurly driving back home at 60 mph all the way the results are the same.
44 miles per gallon is the best the car does.
Tire pressure was varied as well and still no impact.
Going out was 28 pounds and back home I maximized it to the top allowable of 32 front and 34 lbs rear for my Bridgestone Portenzas.
I am wondering if stock Passat of this year get better mileage or not.
Around town has been about 35 to 37 mpg. on dino fuel and a bit more when I use 100% bio fuel.
Any ideas about improving my mileage on the highway?
I am not after performance - just economy.
I am considering increasing my gear ratio by getting larger diameter rims and tires.
Any other suggestions or comments on this little mystery?
I really think there must be something wrong when my mpg is the same when I push the car or baby it when driving cross country.
Clutch is new.
