FredS
I was all set to begin this conversion, then I called Arizona's ADEQ inspection department, and was hit with some bad news. You can't legally do a VW car to Toyota truck diesel conversion! ARGH!!! They referred me to Engine Switching Fact Sheet-1.pdf from the EPA. Google it, its a short read.
So after digesting the bad news a little more I wanted to get better clarification of why this was not a legal swap, when the engine had tighter emission standards than the truck did.
Called today and talked to the same person, was getting more of the same reasoning, then he referred me to one of the supervisors. After talking to the super for about 30mins, my frustration turned to excitement, because the conversion is on.
What he helped clarify was what I had heard from other people, including Jeff at ACME. The process for Arizona(other states don't apply) is to take it to the emission's facility, they'll fail it, as the VIN will come back as gas, and the engine is diesel, obviously.
Then they refer me to the inspection facility, I take it to the ADEQ inspectors(have to fail first), then I have to prove the motor is what I say it is. Documentation, anything that will prove the motor is a 2001 VW TDI from a 2001 VW sold in the US.
My question is, does VW have any engine labels on their TDI motors? This would be the easiest to prove what it is. I own the car, so I have the title, car data plate, vin on dash, but have to see if there is some identifying mark on the motor itself.
Here are some beginning pictures:
Donor 2001 Beetle
The 1994 4x4 ExCab recipient:
Motor running on the floor ready to be set in and mounts built:
Donor 2001 Beetle
