gmenounos
- Joined
- Jun 26, 2003
- Location
- Watertown, MA, USA
- TDI
- '99.5 Golf GLS, '01 Jetta GLX Wagon (TDI conversion)
Replaced a blown front woofer in my '99.5 non-Monsoon Golf. The original was 1J0-035-411D and does not seem to be available anymore. The replacement (bought off eBay attached to a Jetta rear window regulator) is a 1J0-035-411G and is supposed to be the proper woofer for non-Monsoon systems. Interestingly, the original had an inductor/capacitor crossover circuit soldered into the speaker. The replacement has nothing. Sounds fine though.
Kind of a pain that VW used rivets to attach the door speakers. Wasn't sure what the replacement size is. Ended up buying 1/4" (6mm) grip range, 3/16" (5mm) diameter rivets at home depot and they fit perfectly. Shorter ones probably would have also worked.
