sunvalleylaw
What have you guys used that has worked well? My DUK gets here Monday. Thanks!
I thought these cars specifically require GL-4, not GL-5...it's rated GL5
I had the VW spec fluid in my last trans, it definitely got pretty thick in colder weather. I hear the newer VW fluid is better in that regard (their latest manual trans fluid is supposed to be suitable for all their older transmissions too)Did some searching and it seems that some use the Motul, some like Redline 75W90, some like some variant of the OEM VW whether it be 052, 060 or 070. And some are experimenting with GM or Pennzoil Synchromesh. (which I bet are the same). Hmm. I don't want the stiffest of the bunch as I do live up in the mountains. I am tending toward one of the thinner synthetic OEM ones. I also have an email into Frans to see what he recs. He was a champ on the order and shipping of my gearbox, BTW.
^^^ Correct. Most GL5 fluids will corrode the brass synchros in VW transmissions.I thought these cars specifically require GL-4, not GL-5...
Yuri
Let us know what Frans recommends. The FHN he sent me is sitting on the shelf empty as all he ships over are.Did some searching and it seems that some use the Motul, some like Redline 75W90, some like some variant of the OEM VW whether it be 052, 060 or 070. And some are experimenting with GM or Pennzoil Synchromesh. (which I bet are the same). Hmm. I don't want the stiffest of the bunch as I do live up in the mountains. I am tending toward one of the thinner synthetic OEM ones. I also have an email into Frans to see what he recs. He was a champ on the order and shipping of my gearbox, BTW.
With regard to synthetic, not sure what I was saying there. I was meaning the VW OEM, some of which seemed to be synthetic, and which had thinned out as it went toward the 060 and 070. Frans recommended going with oem fluid for the 012 gearboxes. If I can get the OEM stuff reasonably, that is what I will do. If I can't get it reasonably in the time I have, I may go with synchromesh and consider changing it out for OEM in the summer. EDIt: Now thinking not synchromesh, despite a few here having success with it. Hoping just to be on the safe side and use the OEM. I saw Oilhammer post in another thread that he liked it too.Let us know what Frans recommends. The FHN he sent me is sitting on the shelf empty as all he ships over are.
Did you use the regular Pennzoil Synchromesh, and not the "Friction Modified"?I had the VW spec fluid in my last trans, it definitely got pretty thick in colder weather. I hear the newer VW fluid is better in that regard (their latest manual trans fluid is supposed to be suitable for all their older transmissions too)
I wouldn't say the Synchromesh fluid is an experiment by any means, it's been well known as a better alternative to the VW stuff for many many years. Check just about any thread where someone complains about grinding going in to gear and you'll find a recommendation for Synchromesh.
I was actually just thinking to myself the other day how much nicer my trans was shifting this winter... My transmission rebuilder is a VW guy and he sold me on it.
Seriously, I don't want to offend you, but are you really sure about that ?GM Synchromesh Fluid works fantastic. My transmission shifts butter smooth with it.
This is from Frans, the guy from whom I bought my euro DUK for use in my 2005 Passat.Seriously, I don't want to offend you, but are you really sure about that ?
Please note this is a question on the B5 forums, for LONGITUDINAL transmissions, a totally different beast to any TRANSVERSE VW transmissions (which I assume you have from the cars in your signature). Every link to G060 and Pennzoil that are shown above are from transverse applications, NOT THE SAME.
As others have stated, the Audi/VW LONGITUDINAL transmissions have hypoid differentials which require significantly higher film thickness oils to survive. The transverse diffs are very simple by comparison.
I have two 01Es, and I would not put anything other than genuine VW G052-911-A2 in them, or a confirmed equivalent (such as the excellent Titan Sinto 75w80 that Scott sells).
Just my $0.02
In this thread about an A4 Audi.75w90 or 80w90 GL4 of any quaility brand should be fine. Don't use GL5!
I bought some Ravenol TSG from blauparts on clearance. It's a GL-4 synth and from their site info acceptable for longitudinal and transverse VW transmissions.
I think it's comparable to G50 and I've been happy, even in sub-zero weather!
Steve
Yup, been using this for years.GM Synchromesh Fluid works fantastic. My transmission shifts butter smooth with it.
Which is probably a re-packaged Fuchs or Ravenolman. Makes it seem it is easiest just to go with the pricier dealership stuff.
BTW, here is another thread where in the end, it seems like a lot were going for OEM 070 or synchromesh. http://forums.tdiclub.com/showthread.php?t=132884&page=47
