Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Old July 30th, 2010, 11:54   #1
tdiguru
Fuel Economy: 48.3 mpg
Default Engine warning as soon as i cut my car on
Okay so i have a 1999.5 Volkswagen jetta tdi, as soon as i turn the car on it beeps and the red thermometer comes on but the gauge says it is not hot at all, so is this just a system faught and is it okay to drive? Also when i crank it up everything is normal nothing is unusal it sat over night so i know it cant be hot.
tdiguru is offline   Reply With Quote
Old July 30th, 2010, 11:58   #2
d2305
d2305's Avatar
TDI(s): 2004 NB TDI
Check the coolant level.
d2305 is offline   Reply With Quote
Old July 30th, 2010, 11:59   #3
tdiguru
its kinda low not to low just a little below the line, what kind of coolant does it take?
Old July 30th, 2010, 12:06   #4
Fixmy59bug
If the thermometer light is coming on and staying on, it could mean low coolant or the sensor in the bottle could have gone south. If you top up the coolant and the light stays on, then the coolant bottle needs to be replaced.
But if the light is coming on and flashing, then that means the cluster thinks your car is overheating due to a bad ECT.
2009 Jetta: CBEA, DSG, Sunroof, Leather, RNS-510, LED tails (with Amber turns). Built 06-19-2009. Brought Home 08-01-2009
Fixmy59bug is offline   Reply With Quote
Old July 30th, 2010, 12:07   #5
BobnOH
Fuel Economy: 50/45/42
G12 coolant only.
you might want to hook up VCDS and read the ambient temperature of your coolant, Group 007
'~'~my car - '99 Jetta TDI ALH 5-spd
Troubleshooting low power / limp mode.
Trusted TDI Mechanics - By State
Old July 30th, 2010, 12:08   #6
tdiguru
IS this a easy fix or lots of money? we used to have a 2002 1.8t but sold it becasue of the trans. but it had the same problem but it was fine and we never fixed it.
Old July 30th, 2010, 12:21   #7
tdiguru
If i keep a eye out on the temp. and i put coolant in it, is it ok to drive? as long as it doesnt overheat?
Old July 30th, 2010, 12:33   #8
\/\/0J0
\/\/0J0's Avatar
Top up your coolant and keep an eye on the level. If it keeps dropping, you likely have a leak somewhere. I just replaced the radiator in mine(same year) after the seams lost their integrity. Do you have VagCom? It will help in sussing out this issue and any that you will have in the future...
Also, depending on where you are in NC, there are some real gurus around that will be able to help you further so check the list.
99.5 Golf TDI 5spd
Current Mods: E-codes, euroswitch, Elephant Hose, Stealth Race Pipe w/ DG cooler delete, TT bushings, Bilstein TCs w/ GTI springs, Ventectomy, Snorkelectomy, Sprint 520s, RC3, BoostValve, Boost Gauge, Hammer Mod
"Those willing to trade Liberty for Security deserve neither" -Ben Franklin
\/\/0J0 is offline   Reply With Quote
Old July 30th, 2010, 12:34   #9
tdiguru
Also the light blinks it does not stay on. But nothing gets hot.
Old July 30th, 2010, 13:23   #10
MayorDJQ
Fuel Economy: 48/42/39
Send a message via AIM to MayorDJQ
A coolant temp sensor is $16. The coolant bottle is another $16. They're easy to replace. Also buy a $13 bottle of G12.
Don't be a cheapskate. If you overheat and blow the headgasket and/or warp the head, it's going to cost a lot more to fix.
'09 Platinum Gray 6spd. ~36,000 miles. 45mpg best calculated, 44mpg per MFA...so far.
MayorDJQ is offline   Reply With Quote
Old July 30th, 2010, 13:31   #11
tdiguru
Im not trying to be a cheapskate, but there is no point to do something that does not need to be done. But i am going to refill the coolant and see if that works if not ill go from there, but believe me as soon as i see the temp going up past normal i will pull over and have it towed in. ive learned my lesson before
Old July 30th, 2010, 13:55   #12
MayorDJQ
Using that same logic, why bother doing any maintenance, preventive or otherwise?
The temperature gauge is not a reliable way to tell what your engine temp is. "Normal" on the gauge can range from ~170* to ~220* because it's nothing more than a fancy idiot light.
If the level sensor in the bottle is bad, you could have a hose split and all the coolant dump out....and then you overheat. If the ECS is bad the water pump impeller could come off the shaft...and then you overheat.
$45 in parts and a hour of labor may wind up saving you a lot of money.
Old July 30th, 2010, 14:54   #13
tdiguru
Well actually thank god, i drove halfway down our long long driveway and it went off, and once it got to its normal temp it stayed there so maybe a system glitch or something idk? but i will make a trip to get some g12 coolant tomorrow and fill it up just to be sure but thank gosh it is drivable.
Old July 31st, 2010, 11:49   #14
tdiguru
it just needed coolant. thanks everyone
Old July 31st, 2010, 15:40   #15
\/\/0J0
\/\/0J0's Avatar
As I advised previously; there's usually a reason that coolant is low. You have fixed the symptom, now look for the cause. ..my .02
99.5 Golf TDI 5spd
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.10996 seconds with 12 queries
[Output: 111.68 Kb. compressed to 91.09 Kb. by saving 20.59 Kb. (18.44%)]
