Boost, EGT, Oil temp and pressure. 2 on the column, 2 on the a pillar.
I also run a 12v cig plug voltmeter. I'm a HUGE fan of a voltmeter vs the idiot light.
Over my millions of KM driven, it potentially saved me a tow bill or CAA call when the alternator went wonky and/or died. Once the idiot light goes on, it could be too late depending where you are. Unless you want your car fixed at a nearby "unknown" garage... horror stories
The voltmeter gives you a direct reading... if a rectifier goes, you can see the voltage go up and down and all over the place, a hint that your alternator is on its way out. It just gives you TIME to deal and assess the situation.
Also.. it'll give you a nice reading when you start your car. You can see the voltage dip when you crank it over. When you start getting in the low 9s, it's time to get a new battery. Another possible item that could leave you stranded somewhere you wouldn't want to be!
And they're dirt cheap, direct wire in the fuse box or cig plug like me.
