D DMCC Active member Joined Jul 24, 2014 Location UK TDI 110 TDI MK4 Jul 21, 2017 #1 1111111111111111111111111111 1111111111111111111111111111 Last edited: Apr 26, 2018
H Henrick Top Post Dawg Joined Aug 24, 2010 Location Ireland TDI Golf VI TDI, 77 kW (CAYC) Jul 22, 2017 #2 Quick way to check is the fan is working is start the car and turn on the AC to cold. Fan should start running withing a minute or sooner. Which water pump did you replace - the mechanical one or electric one? Do you have a scan tool? Any faults in Engine section?
H Henrick Top Post Dawg Joined Aug 24, 2010 Location Ireland TDI Golf VI TDI, 77 kW (CAYC) Jul 23, 2017 #3 The fan is OK then. Are you 100% sure this isn't a regen? Also, have you performed the VW "recall" or "fix" for the emissions? 100 *C is not something unusual, especially going uphill. Nothing to worry about.
