Good evening, so after a month of reading here and in a couple of ecu related forums I got an ebay cable, pulled all the maps and basically just raised the limiters a bit and calculated smoke limiter to always be above 18, turbo pressure was raised to a max of 1.15Bars/2150mBar absolute.
Its a bone stock ALH engine in a Jetta/Bora chassis, with 270k km's.
The only log I have for now is Group 11 to see if I was killing my turbo:
https://malonetuning.com/graph/view?log=410
(Thanks Malone for this sweet tool)
The log was done with 5 people on the car(didn't have a lot of time, so grabbed the laptop and during the trip I did the log on the high-way, no cars, legal to go as fast as the 3rd gear pull would put me, gave it a quick glance and was happy because there was no crazy overboost spiking.
So far, it feels like almost a different car, a lot more responsive in any gear, so far fuel usage is a bit higher, because its fun to push it, top speed is the same(195Km/h) but now it pulls decently fast to 180km/h even on hills, I expected that top speed wouldn't change, because the engine is around 4200 rpm in 5th gear at those speeds, and power at those rpm's is dropping from a cliff..
Now, what do the gurus think about the log, should I tweak the N75 map, and what else should I log?
Best regards.
Best regards.
