Old November 28th, 2015, 16:25   #1
Nick928
Default Car Wont Start, Immo lights ok, 2007 1.9 tdi VW Polo AXR enginge
Hi there, my name is Nick , I own a couple of Skoda Octavia TDI Wagons over the last 7 years (still own) and a VCDS.
I just bought a 2007 1.9 tdi AXR VW Polo, that starts then dies, even with accelerator to the floor there's no change.
The area i bought the car from is 2 hrs drive west of Brisbane , Australia , so its generally bone dry , warm (in winter, currently almost summer) and quite a lot of dirt roads (3 minor Kangaroo hits, no major damage apart from cracked bumper etc) . So the car might of been shaken within an ace of its life. It does however have lots of new bushes and suspension etc.
The car was driving, then suddenly cut out while driving and would not re-start.
The car fires up for a second or 2, then dies. Or more recently tries to fire but doesnt.
Here are the VCDS readings with issues, obviously there is one glaring one, though the car does try to start, so i thought i'd put it all down for the masses to glean over before i start needlessly pulling items of car off.
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Q0 820 045
Component: Klimaanlage X0840
VCID: 6AD1F19816949B6EE3-512E
2 Faults Found:
00705 - Relay for Coolant Fan; Stage 1 (J279)
31-00 - Open or Short to Ground
00706 - Relay for Coolant Fan; Stage 2 (J513)
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 F
Component: 0009 BN-SG. 2S36
Coding: 09358
Shop #: WSC 31414
VCID: 3E790DC83A9CC7CE6F-5112
2 Faults Found:
01314 - Engine Control Module
49-00 - No Communications
01598 - Drive Battery Voltage
07-00 - Signal too Low
I've checked the battery.
In tank lifter pump is working and good pressure seems to be ok at the filter in eng comp, though bubbles can be heard in tank (seat is now up) when ing turned after being left for 10 15 mins.
No Immo light on dash after engine cuts
Glow plug lights up ok
Tried both keys
Accelerator doesnt work (once i managed to get it to run for 30 sec, but was low idle)
Car is covered in thick dust, have just jet washed eng comp
Fuel is getting back to the filter after going via the engine.
Apart from the Control Module (obviously the VCDS shows something) , i want to rule out jumped cam belts , failed pumps etc etc.
I found this PDF to be a lil helpful as reference https://www.dropbox.com/s/x5ibckz73n...eDuse.pdf?dl=0 But i thought i really should post here before going further.
Thanks in advance.
Nick
Nick928 is offline   Reply With Quote
WinOLS - UK Polo PD100 AXR Map Yohan TDI Power Enhancements 0 September 24th, 2014 12:28
UK Spec Polo (2006) - 1.9 PD100 AXR Vac System Upgrade Yohan TDI Power Enhancements 6 September 18th, 2014 14:12
2007 vw jetta 5 wont start Bergill TDI 101 1 September 28th, 2012 01:37
2000 jetta auto wont start. instrument lights/gauges don't light but car cranks minicorrado TDI 101 15 July 31st, 2008 15:48
Page generated in 0.13289 seconds with 11 queries
[Output: 48.52 Kb. compressed to 45.85 Kb. by saving 2.67 Kb. (5.50%)]
