Old December 9th, 2012, 14:21   #31
What do you mean by "downgraded on design"?
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old December 9th, 2012, 14:32   #32
v1k1ng01
v1k1ng01's Avatar
Fuel Economy: 40
Perhaps “downgrade” is the wrong verbiage what I really meant was “adapted design”. Apparently though I haven’t verified this, the US spec 2.0TDI received some engine adaptations to meet EPA emission regulations. This took the shape of several engine components being for lack of better terminology “nerfed” though I’m sure VW would say adapted. If you go through my thread, the euro 140CR and the 170CR have all same parts except the turbo, whereas the US 140CR has a slew of different parts from the 170CR.
v1k1ng01 is offline   Reply With Quote
Old December 9th, 2012, 16:58   #33
I started a similar thread recently, hadn't seen yours. http://forums.tdiclub.com/showthread.php?t=370184 Seems it's more than turbo. Cylinder head, injectors, HPFP also seem to be different.
I think it's pretty difficult to tell why VW or any manufacturer puts different components in different models. For example, why are there significant differences between the Passat and Golf/Jetta engines? Is it only because of Urea? Does that require a water cooled intake or a different turbo?
Supply chain considerations, proximity of component suppliers to engine assembly plants, impact of emissions hardware changes on engine tuning, different countries' safety equipment changing vehicle weight and therefore emissions...lots of things can affect "engineering" decisions.
Old December 10th, 2012, 05:03   #34
v1k1ng01
v1k1ng01's Avatar
Fuel Economy: 40
^------ Yeah I had a list of half dozen things on US Spec TDI's that was different then the 170CR. http://forums.tdiclub.com/showthread.php?t=354586
Old December 15th, 2012, 19:57   #35
Front Runner
Originally Posted by Lujess View Post
Trying to evaluate whether to stick with it or sell and move to GTI.
Opinions welcome - thanks
OP,
I think you brought the wrong car for your intended use. Sell it and get the Turbo gasser. You'll have less mpg's but wont have to deal with this stuff. I personally believe you'll continue to have these types of problems with your vehicle.
Front Runner is offline   Reply With Quote
Old December 17th, 2012, 06:35   #36
Lujess
Originally Posted by Front Runner View Post
OP,
Thanks for the comment - yes, I've come to the same conclusion. Now just pondering whether to go GTI or R.
Lujess is offline   Reply With Quote
Old December 19th, 2012, 13:48   #37
v1k1ng01
v1k1ng01's Avatar
Fuel Economy: 40
Get the R! Sure it's more money but it's more car! Only way I would get the GTI over the R is if I had my heart set on a DSG. That my openion anyway...
Old December 22nd, 2012, 21:21   #38
Front Runner
Either one will put a smile on your face. It all depends on how much you wanna spend.
Old December 24th, 2012, 05:47   #39
Lujess
Yes. Test drove an R this weekend......lots of smiles :-)
Old January 14th, 2020, 22:37   #40
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: 25.5, combined
Resurrecting this old thread because it's the only one I can find regarding code P0240f.
My 2009 Touareg Tdi is also getting this code. It will post the code for 100 or so miles, then magically the MIL light goes out for the next 100 or so. In an average tank (I've only had it for 3 tanks of fuel) it comes on 2 or 3 times.
My typical driving is between 7-22 miles, but I always try to get the engine oil temperature to operating range before shutting down. I do tow 2500 lb trailer about half of the driven miles.
The MIL light will typically come on when I accelerate moderately at freeway speeds (no kick down of gears occurring). I suspect clogged intake, but this is a dieselgate warranty vehicle, and it was supposedly serviced during the dieselgate resolution.
I'll soon be taking it to VW Scottsdale (excellent shop with superb service), but I am just wondering if this has been a recurring problem for other Tdi owners, and what was the cause and resolution for you?
BTW: I can sometimes feel a noticeable hiccup on power delivery. I don't know what to attribute it to other than start of regen?
nicklockard is offline   Reply With Quote
Old January 16th, 2020, 13:34   #41
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
Im glad these older threads pop up occasionally, it can be telling of pre-dieselgate issues relative to post-diesel "fix" issues. I found alittle on a po240f search
http://p240f-volkswagen.autotroublecode.com/
JELLOWSUBMARINE is offline   Reply With Quote
DPF and EGR replacement splatmatic VW MKVI-A6 Jetta Sedan (~ 2011+) 8 October 14th, 2012 20:05
dpf/ pressure differential problems thjett TDI 101 3 January 11th, 2012 06:33
DPF problems abedini VW MKIV-A4 TDIs (VE and PD) 0 September 25th, 2010 15:29
DPF problems Phill1060 TDI (Diesel) Emissions 2 August 9th, 2007 07:54
Page generated in 0.17826 seconds with 13 queries
[Output: 110.41 Kb. compressed to 94.26 Kb. by saving 16.16 Kb. (14.63%)]
