Old January 12th, 2020, 02:40   #1
@Tdi VW
Default Alignment done, car still pulls to the right
Hello
Car was always pulling to the right and recently I changed wheels and put new tyres. Every time i let go the steering wheel car sloooowly pulls to the right
i had the alignment done by a professional shop and they guarantee they did it right and the car is doing the same thing even after new tires and wheels.
Any idea ?
Sent from my SM-G925F using Tapatalk
@Tdi VW is offline   Reply With Quote
Old January 12th, 2020, 05:53   #2
mozark
Are you checking this on a level, non cambered, surface? such as a parking lot.
mozark is online now   Reply With Quote
Old January 12th, 2020, 05:57   #3
@Tdi VW
Well i can notice this on highway a like 50-60mph. On a parking lot it looks like it goes straight
Old January 12th, 2020, 06:41   #4
PickleRick
PickleRick's Avatar
Have you double checked tire pressure in all 4 tires?
Any time i feel a pull to one side I've usually picked up another nail
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old January 12th, 2020, 13:09   #5
@Tdi VW
Yes sire, tyre pressure checked
Old January 12th, 2020, 15:02   #6
Zambee500
Did they set/adjust raised toe when they aligned it?
These cars have the Audi front suspension with toe adjusts up/down and in/out.
2005 Passat GLS TDI (sedan)
Zambee500 is online now   Reply With Quote
Old January 12th, 2020, 18:56   #7
I'm having the steering rack replaced in my B4 Passat because despite new tires and a perfect alignment it drifts right. Drift is stronger then it's cold out. My guru says it's bias in the steering rack., caused by age. We flushed the fluid a while ago and that didn't help. We'll see if the new rack fixes the problem.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old January 14th, 2020, 13:47   #8
imo000
imo000's Avatar
Fuel Economy: Good enough
Most roads have a crown so depending on what side of the crown you are, that's the way the car will slowly pull. The crown is for drainage. Imagine that the cross section of the road look like the roof of a house but with much smaller slopes. The roof peak is usually the centre line if the road only has a couple of lanes each way. If it has more the peak will be somewhere in the middle lane. The gutter would be the shoulder or the ditch of the road.
imo000 is offline   Reply With Quote
Old January 18th, 2020, 00:16   #9
@Tdi VW
I swaped front tyres( both brand new) and it seems that it got a liiil better.
Ill just leave as it is
2001 Golf Alignment Pulls to Right Gto7784 VW MKIV-A4 TDIs (VE and PD) 15 November 1st, 2019 20:28
alignment supposedly good, but still pulls to right gcarl0 VW MKIV-A4 TDIs (VE and PD) 7 August 6th, 2019 17:31
car pulls to the right AARodriguez Corp. TDI 101 9 June 29th, 2012 07:48
she pulls to the left - after an alignment?? tdipoet VW MKIII-A3/B4 TDIs 16 February 23rd, 2003 18:37
New car pulls to left Imran Upgrades (non TDI Engine related) 1 November 15th, 2000 06:04
Page generated in 0.14199 seconds with 13 queries
[Output: 90.76 Kb. compressed to 77.56 Kb. by saving 13.20 Kb. (14.55%)]
