JoeBleed
Since i am going to be doing this in a week or two for my 50k maint. and it has been 2 years now, i have a question.
Why did you have to refill the resavore?
I thought the fluid was supose to be pored into the Motive presure bleeder tank and then pumped into the resavore through the whole process. Unless you meant the Motive tank.
This does also displace/replace the fluid in the ABS pump with out running an output test on the pump to move fluid through it, correct?
Thanks.
Thanks.
