RayBrubaker
I've searched this subject but not found much, apparently this is not a common failure. Fluid was lost from the pump seal, bearing failing/shaft is loose. there is fine metal flake visible in the reservoir so metal is through the system. Is there any hope of flushing the system well enough to save the rack? Has anyone done this successfully? If changing the rack, can the lines be cleaned well enough. I searched for info on changing the rack but didn't find it. It doesn't look like an easy job, any pointers/tips would be appreciated.
Thanks for any help,
Ray
'96 Passat wagon TDI, 313k
'97 Passat sedan TDI, 298k
'89 Vanagon Blue Star
'87 Vanagon Westy Waiting for TDI conversion
Ray
