I was eomdering would had abs sensor make airbag come on?Don’t you love the rust?
Drill, hammer & punch, round file to clean up the hole. After a year in the rust belt these sensors just don’t come out without a fight.
Yea if you didnt stop drilling!I would remove the wheel bearing to remove it. If it is the same as my Jetta any bits that get pushed through or fall inside will probably damage the wheel bearing seal/toner ring.
