SoCATDI
- Joined
- May 18, 2009
- Location
- CA for 36 yrs-now in TX
- TDI
- 2005 Passat TDI GLS Wagon, 2003 Golf TDI, 1998 Jetta TDI sadly totaled by teen driver, 2014 Jetta SportWagen TDI
The Passat is back on the road after the Head Gasket was replaced. I threw on a new turbo I had purchased years ago. And thought she was good to go. Local VW dealer did the work for many reasons including my poor eye sight. Alas, not is all good shall we say. The car is being used by my daughter and it keeps letting her down stranded several times. It is a fuel supply issue I think. The fuel pump was replaced and the Passat refused to start again after 7 cycles. Towed back to the dealership again. What do you guys think? You have given me such good help in the past, the dealer is obviously stumped!!!
Is there a relay or solenoid that shuts off the fuel to stop the engine?
Is there also a relay or solenoid that allows fuel to pass to the engine on
start up?
Or are there endless options on this failure to start problem?
socal in need of help!!!!!!!!
start up?
