Hey to all. I posted below about a non-running tdi that I just picked up. I suspected it was locked up, but wasn't sure. Today was the first chance I've had to look at the car. I pulled the valve cover and the lifters looked good from what I could tell. I was able to rotate the crank almost 90 degrees back and forth. Next, I pulled the glow plugs, and #3 was completely soaked. I went ahead and tested each one, and they are all good. Next, I tried to turn the crank by hand again, and I was able to. Black, liquid death sprayed out and covered everything...well, almost everything, but I was excited to see that the engine was at least not seized. After gently releasing a little more midnight juice by hand, I was dumb enough to cover the glow plug opening with some rags and I thought I'd just bump the starter with the key, so I did. Ok, so this is what really DID cover everything with darkness. I have honestly never seen anything make that much of a mess...never. I stopped and cleaned up everything except for the engine compartment. So....
How do I properly empty this cylinder and not make everything look like nighttime?
Also, what could have caused this hydrolocked condition? I am assuming this is oil/diesel and not water, but I honestly don't know yet. PO said he drove it to work one day and all was normal. When he came back out after work, the car would not start. What do I need to look at here? This is my first diesel. Thanks in advance for any suggestions!!
Oh yeah...this is a 99' ALH.
