xjay1337
Unfortunately I couldn't find a Col. Sanders outfit, instead only my Rolf Harris one.
That would be interesting to see, just looked through all my old graphs and the only run I have on 4F was when JKM dyno'd it as a T5 130 with just an upsolute remap and it made 160.I'll post tomorrow shoot 4, 6 and 8 from a car we have on there
Also made a rookie mistake and turned up with 3/4 tank of fuel so could probably nock another 60-80kg off as it's got the bigger factory tank fitted.Well done Martin.
Decent terminal speed for a van.
With a better start i think you should hit 15s dead.
Decent gains for a build on hybrid.
Second morgage yes.... I'm going to throw another £7k at the engine to see if I can hold it together but yes you are right "I have found the upper limit" at the moment.You have decent spool and makes decent top end power.
If the unit goes then maybe consider a 2260vk
From Chris’s experiences we already know the safe limit without taking out a second mortgage.
