Old May 9th, 2016, 05:50   #16
Stromaluski
Stromaluski's Avatar
Originally Posted by compu_85 View Post
I've always loved that color. Nice to see a MK3 getting some care
-J
Thanks!
-Andrew
Stromaluski is offline   Reply With Quote
Old May 10th, 2016, 06:57   #17
mrrhtuner
mrrhtuner's Avatar
Very nice car.
Keep us posted :-)
mrrhtuner is offline   Reply With Quote
Old May 11th, 2016, 19:21   #18
rocketeer928
rocketeer928's Avatar
Very nice looking Jetta.
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
rocketeer928 is offline   Reply With Quote
Old July 15th, 2016, 06:27   #19
Stromaluski
Guess it's about time for an update. Borrowed some Corrado Steelies from a friend to see how they looked on the mk3. I never really liked the Sebrings.
Also went through the hassle of replacing the Condensor and recharging the system after I mangled the one in the car during the clutch replacement.
Got the bottom half of a nice passenger seat from the junkyard and used it to replace the foam on the base of my driver seat since the outer bolster was blown out.
Also threw in a new (illuminated) shift knob. It's kinda corny, but I really like it.
Had to replace my stock head unit after it ate itself.
Had this one sitting in the garage, so I threw it in. It's not great, but it had the advantage of I already had it.
-Andrew
Old August 31st, 2016, 09:40   #20
1998TDIMonster
Fuel Economy: 44 AVG. 48 Hwy best
Any more news on this one? That headunit looks great.
1998TDIMonster is offline   Reply With Quote
Old August 31st, 2016, 10:36   #21
dieseldorf
top post dawg
dieseldorf's Avatar
Andrew, nice lookin' ride! We don't see MkIII cars any longer....rust has taken them...
Old August 31st, 2016, 18:52   #22
rocketeer928
I like the illuminated shift knob. Where did you get it? I have an Gaslock Indy-Cator on my TDI, which is also corny.
yo
Old October 3rd, 2016, 05:37   #23
Stromaluski
Sorry! Need to check this more often...
Head unit came from Jaycar, though I can't seem to find it on their website anymore. It's a knock off of a Kienzle head unit. The quality of it isn't great by any means. But it looks like it could be a factory radio out of something, which is what I was going for. And it wasn't terribly expensive, either.
http://www.jaycar.us/
Shift knob came from Innovative Car Tech in Germany. I would definitely buy another one.
http://www.innovativcar-tech.de/en/
I also finally got around to replacing a bunch of the stereo system in the car. Speakers had definitely seen better days. Almost all of them looked like this.
Ended up with Sound Ordnance component setups in front and rear with a Sound Ordnance powered subwoofer mounted to the back of the rear seat. Sounds good to me. I ended up mounting the crossovers in the rear by sandwiching the rear parcel tray between some sheet metal and the crossovers. Left the factory front tweeters mainly because I didn't want to have to mount crossovers up front. Driver side one has already been mounted in the picture below.
Also hard wired my dash cam while I had the interior all apart. FYI, you can pull switched, fused power from the fuse box by tapping into the rear wiper circuit. The rear wiper is not present on Jettas, but power still makes it to the relay slot on the fuse box.
Currently been trying to figure out why I keep getting my a/c draining onto the passenger front floor, but only at certain times. Seems like it's only if I'm doing 50/60 mph or above that it happens. And almost seems like pressure in the engine compartment pushes the draining water between the drain and the firewall seal... Never heard of the problem, but that's where it seems to be coming from.
-Andrew
Old June 8th, 2017, 22:08   #24
benIV
benIV's Avatar
ever figure out that ac/drain problem? How's the little jetta doing?
OCD TDICLUB MEMBER #6 - 2003 TDI Mafia Member
Orville, 2003 Jetta 5m Sedan, Platinum Gray
Wilbur (Knurren), 2003 Jetta 5m Wagon (Golf Variant), Reflex Silver
1974 Super Beetle Conv
1986 Mercedes 560 SL
1956 Chevy Truck - Hot Rod
benIV is offline   Reply With Quote
Old June 17th, 2017, 06:24   #25
Stromaluski
I guess I'll update this again. I haven't done a whole lot with the car other than driving it. Primarily been working on my mk1 and my bus. In any case, though...
Picked up a second set of Corrado Steelies.
Had them powdercoated and put a new set of 195/55/15's on them. The powdercoater did a terrible job on them. The powder is too thin (in addition to being more white than silver); so now a few months later, there's surface rust coming through the powder.
Swapped a stock head unit back into the car and put the JayCar one back on a shelf. I really like the look of a stock head unit.
Started buying parts to put a bigger turbo on the car, but that won't happen until later this year or possibly into next year. Picked up a BHW exhaust manifold and PD130 intake manifold and picking up an 11mm injection pump from a local friend hopefully this weekend.
I put a zip tie around the seal where the drain passes through the firewall and tightened it just enough to put some pressure on the drain. Hasn't done it since. I still have never heard of the drain not sealing, but it seems to be fixed. In any case, though, I don't really give the car a whole lot of love.
At this point, the paint is fading through to primer on both the roof and trunk and the paint on the front bumper/grill/hood is really looking terrible. I need to do something about it, but don't want to go through the time/expense of painting the car. Thinking I'll just plastidip the whole car...
-Andrew
FS:98 porcelain blue tdi 4800 obo gabes tdi TDI Cars for Sale/Wanted 7 June 22nd, 2011 00:55
PORCELAIN BLUE DRIVER Jetta/Bora/Vento TDI Picture Gallery 7 September 14th, 2010 05:13
FS: porcelain blue touch-up paint and clear coat PORCELAIN BLUE sameoldmike Private TDI Items for Sale/Wanted 1 June 5th, 2007 13:10
Porcelain blue Touch-up Paint keks VW MKIII-A3/B4 TDIs 9 April 24th, 2007 20:59
Porcelain Blue A3 TDI spotted on my commute today! Peter Cheuk VW MKIV-A4 TDIs (VE and PD) 0 September 17th, 1999 07:57
Page generated in 0.11552 seconds with 11 queries
[Output: 106.46 Kb. compressed to 91.34 Kb. by saving 15.12 Kb. (14.20%)]
