Old July 8th, 2014, 07:09   #1
papi123
TDI(s): 1.9tdi 1z
Default 5 bar map sensor
Can anyone help here i need 5bar map that will work with EDC15 on my ASZ engine
papi123 is offline   Reply With Quote
Old July 12th, 2014, 09:49   #2
tdi_my live
TDI(s): Skoda Fabia
Have you Hardware and Datasheet?
tdi_my live is offline   Reply With Quote
Old July 12th, 2014, 11:02   #3
bonham123
May I ask what you need a 5 bar map for?
bonham123 is offline   Reply With Quote
Old July 12th, 2014, 11:56   #4
papi123
TDI(s): 1.9tdi 1z
for 4 bar boost pressure probably
Old July 12th, 2014, 12:19   #5
bonham123
That clears everything up.....
Old July 13th, 2014, 01:42   #6
tdi_my live
TDI(s): Skoda Fabia
Sorry my english is not good.
I understand right?
You want use a 5bar presure sensor with 4bar map?
I asked have you a 5bar sensor?
Old July 13th, 2014, 09:34   #7
Mikko.P
http://tinyurl.com/aolvcj6
This is what i have used. Just need to make the calibration to your tune...
Mikko.P is offline   Reply With Quote
Old October 9th, 2017, 12:12   #8
bugija
Mimo.p i bought this map sensor and it working for 0.5 bar well vnt doesnt work you can calibrate it from 0 bar ? Or somebody can?
bugija is offline   Reply With Quote
Old October 9th, 2017, 23:52   #9
FRITS91
0.5 bar is the absolute pressure.
atmospheric air pressure of 1 bar.
it turns out your sensor can see even 0.5 bar of discharging. The discharge happens only where there is a choke - in a diesel it does not matter eto.vyy just do not properly prescribe. I went from 5 bar mp from the Volvo - everything worked
VW Passat B3 TDI Syncro
http://www.drive2.ru/r/volkswagen/1132946/
FRITS91 is offline   Reply With Quote
Old October 10th, 2017, 09:16   #10
bugija
Ale right i Sand you Priv massage
Using 3 bar map sensor on 2.5 bar map car devonutopia TDI Power Enhancements 36 October 5th, 2016 09:17
3 bar, 2.5 bar map sensor, thermo switch blitzed Private TDI Items for Sale/Wanted 6 March 29th, 2014 14:09
3 Bar Map Sensor cawmere TDI Power Enhancements 1 November 13th, 2010 08:58
3 Bar Map Sensor 00JettaTDI TDI Power Enhancements 3 November 6th, 2007 20:49
3 Bar Map Sensor Help choramix TDI Power Enhancements 6 August 10th, 2006 16:03
Page generated in 0.14729 seconds with 11 queries
[Output: 91.62 Kb. compressed to 77.60 Kb. by saving 14.01 Kb. (15.30%)]
