Jetta_Pilot
- Joined
- Apr 14, 2005
- Location
- West Hill, Ont.
- TDI
- 2015 Passat Highline TDI Candy White (SEL Premium) long gone 2002 Jetta TDI
I just returned from a 4 week European trip and had parked my car at an airport parking lot.
Got into the car yesterday afternoon, car started fine.
My own inattentiveness, but when I was on the 401 I noticed that I had no RPM counter, no speedometer, no water temp and no fuel gauge. Odometer and trip meters were OK. Used my Scangauge for speedometer which worked fine.
Parked the car overnight and went out today to see if either fuse Nr.11 or Nr.15 could be the culprit. Had to start the car to get it out of the garage and all was well ????
Turned engine off and pulled Nr.11 fuse. Car starts but stops immediately.
Pulled Nr. 15 fuse and car starts but no instruments, ie same I had yesterday.
Could it be a wonky Nr.15 fuse that when cool is OK and car if or when the interior is hot as it was yesterday afternoon and then it acts up???
Nr.11. Instrument cluster, shift lock solenoid (5A).
Nr.15. Instrument cluster, transmission control module (TCM) (5A).
Any thoughts?
Any thoughts?
