2006 New Beetle TDI BEW engine, 72, 000 miles.
I ordered a new Intake Manifold Flap and put it on. I took the old one off and the flap seemed to be working just fine. I didn't pry off the back cover just in case I want to reuse as a get me home. With just a couple of tools one could be done in about 10 minutes on the side of the road.
Now here is the problem. I used my OBD and checked everything when I still had the supposedly bad one on and after doing a reset and cleaning it (Flap Motor), everything checked out fine. Then the engine check light would come on in a couple of days. The one thing I noticed is what I call a pulsing I had my wife step on the accelerator and I could watch the flap go up and down as if it was letting air in and out. When all was closed up I could still here it pulsate. It doesn't do it if you step on it or back off. Looking at it with the hose off, step on it, it opens to let air in back off it closes to reduce air causing a breaking or back down. I think that is all normal except the pulsing when driving at a steady speed. Say I'm driving in 5th gear at 65 mph you can hear it opening and closing. There is no difference in RPM, no surging, no fuel or power loss. This was also checked with the OBD.
Now I put in the new one and it's louder and I can hear it even more. The check engine light has not gone on but it has only been a day. I checked all fuses and tested voltage to the flap motor and it was at 13 or better with the engine running and no fluctuation in current to create a pulse.
Is this the way it's suppose to operate. I never noticed it before and I'm wondering if I just started noticing it because of the original diagnosis and changing out the flap motor. And, there are no error codes on the OBD. The only other thing I thought it might be is the MAP sensor but that should show a code if it’s bad, I would think.
Any suggestions or help would be appreciated.
Thanks,
Max
Thanks,
Max
