IXLR8
My car has been sitting since the first of the year, just over two weeks ago I noticed some yellowish fluid coming out from under my car. I thought it was just snow/slush finally melting and I ignored it, but after 2 weeks it hadn't dried up. When I checked it out I discovered it was slippery... hmm that is not snow melt. Having a bad feeling, I pressed on the clutch pedal and it just flopped to the floor, the brake/clutch fluid reservoir is also empty! I have also seen signs of mice being in engine compartment, they have chewed a big hole in the battery blanket right next to the b/c fluid reservoir. I can see a hose going from near the top of the reservoir down behind some insulation and I don't know where it goes from there. I don't see the clutch master cylinder, I am assuming it is hidden behind the above mentioned insulation somewhere. I see no sign of fluid where the clutch master pokes into the passenger compartment. Can someone tell me what I need to do to get so I can see the clutch master cylinder and give me a hint where the clutch slave cylinder is. The car is sitting under my lift and I can only jack it up 6-8" before I hit the lift. So I would like to have an idea where the clutch slave cylinder is to minimize jacking. Although I suspect that I am going to have to remove some belly covers to be able to see the cylinder anyway. I just tried to download the electronic manual and that didn't work, so any help folks could provide would be appreciated.
Thank you,
Thank you,
