krekavhts
2003 Jetta GLS TDI 5spd Wagon Green – 350,250 Miles
Fully loaded wagon with black leather, ASR, sunroof, Monsoon
Ipswich Massachusetts
$5500obo - Less if you don't need snow tires or VCDS Cable
Bought in fall of 2013 from TDIClub member in NH. The car was well maintained and included a number of performance modifications. I have completed a number of large maintenance items over the last year and improved overall performance a great deal. I have enjoyed owning the car, but life changes are forcing me to sell. I don't have room to keep along with dedicated track day car.
Car had extensive VW Warranty corrosion work done in June of 2014. New drivers side fender, drivers wheel well rocker work and entire new lift gate. The only rusty spots on the car now are the hood (rock chips), passenger lower fender and a ding on the drivers rear fender. See pics. Underside car has rusty bits, but for a New England car, its pretty darn good.
Performance modifications (50+ MPG on highway, mixed commute avg 48):
-Koni Street w/ Shine Real Racing front springs/towing rear+tophats & bushings @ 330k
-Rocketchip stage 3+ (August 2014)
-3 BAR Map (August 2014)
-VNT-17 at 300k
-PP764 at 320k
-OMI Intake (OEM Box with filter at 345k)
-EGR Delete
-IDParts 2.5” Turbo back (brand new heavy duty SS Vibrant flex coupler @ 350k)
-SS Intercooler Piping
-PD In tank lift pump with appropriate wiring (re-done @ 330k)
-Southbend Stage 3 Clutch @ 300k
Panzer Plate
-.658 5th Gear
-Redline Trans Oil @ 350k
-Dashboard Mod – Boost Gauge in RPM Cluster. Cool
-EGT Probe setup for use with Fluke Temperature Monitor
-Major Maint:
-Continental 100k T-belt at 310k
-Continental serpentine @ 335k
-Fuel Lines from tank (previous owner, good condition)
-Coolant Sensor, coolant flush and T-Stat @ 335k
-All Pump Seals (Viton) @ 335k
-Pump Case Pressure valve @ 345k
-MAF @ 350k
-Vacuum system overhaul @ 350k
-Front calipers and wheel bearings @ 325k
-Lots of electrical work including new ignition switch, re-grounding
-Main radiator/condensed fan @ 340k
Current Maint:
-Oil, filter and bypass filter @ 350k (LiquidMoly 5w-30)
-Fuel filter @ 345K
-Air Filter @ 345k
Condition:
-Exterior 8/10 after work by VW
-E-Code Hella lights installed and in great shape
-Roof rack OEM VW with Locks
-BBS 16” 2 piece with 15k miles on Hankook Ventus Noble S2 tires (205/55/16)
-Winter Wheels OEM 15” wheels with Michelin X-Ice 3's in front @%70, rears are X-Ice2's and will get thru this winter but thats it
Interior 8/10:
Small tear on drivers seat. All other leather in great shape with very little wear.
Includes Monster Matts
Monsoon Stereo w/ 6 disc changer works great, sounds great
New hvac fan resistor
AC system gone thru over the summer and working well
Additional:
RossTech VCDS VAG cable (Nov 2013)
Shine Racing rear springs (Need spacers to use, I like towing springs better)
Lots of spare parts
Metalnerd injector wrench and other tools
Spare BBS Wheel
Things to consider still working on:
-PP764's are great for power, but still smoke some on full tilt. If it bothers you, I'd go to Sprint520's and update the tune with Jeff @Rocketchip
-Last alignment was 9 months ago, I try and do every 6 months
-Control Arm bushings and subframe bushings, I have them from IDParts, just never got around to installing
-Washer reservoir level sensor not working, light comes on, annoying beep
This is a great wagon, it was a hard decision to sell. I just have so much work to do on my BMW track car that I needed to sell something. At 350k, its a good car, but with a 100k Acura in the driveway as well, the lack of wrench turning on the DD wins out...
Jeff
Email
NERsoloNovice at gmail
-VNT-17 at 300k
-PP764 at 320k
-EGR Delete
Panzer Plate
-.658 5th Gear
-Major Maint:
-MAF @ 350k
Current Maint:
-Fuel filter @ 345K
-Air Filter @ 345k
Condition:
Interior 8/10:
Additional:
Lots of spare parts
Spare BBS Wheel
Jeff
