Old February 21st, 2019, 14:44   #1
Toyomike
TDI(s): 2004 Golf
Default EA288 Thermostat Replacement
Just about to roll 100K, I have found numerous timing belt kits. But I canít seem to find anything on thermostat replacement. I have always replaced this with ever timing belt. Can someone please give some insight on what needs to be done with this during the 100k service.
Sent from my iPhone using Tapatalk Pro
Toyomike is offline   Reply With Quote
Old February 21st, 2019, 17:34   #2
Lightflyer1
Lightflyer1's Avatar
What car? You only have a 2004 Golf listed.
Old February 21st, 2019, 19:34   #3
sands80
Fuel Economy: 46.4mpg
Is this what your looking for?
Maintenance
sands80 is offline   Reply With Quote
Old February 21st, 2019, 20:12   #4
Toyomike
TDI(s): 2004 Golf
Oops, itís a 15 Golf
Old February 21st, 2019, 20:16   #5
Toyomike
TDI(s): 2004 Golf
I canít find anything on thermostat replacement, or parts.
Old February 21st, 2019, 21:22   #6
Ol'Rattler
Ol'Rattler's Avatar
Originally Posted by Toyomike View Post
Just about to roll 100K, I have found numerous timing belt kits. But I can’t seem to find anything on thermostat replacement. I have always replaced this with ever timing belt. Can someone please give some insight on what needs to be done with this during the 100k service.
No real reason to replace the T-Stat at the first T/B change on any Dub but I did look and couldn't find a T-Stat either. I am surprised. TheT/B kit does look pretty reasonable though. https://www.idparts.com/timing-belt-...ca-p-7237.html
Almost forgot. isn't your T/B interval 130K miles?
EA288 Familiarization: http://pics3.tdiclub.com/data/517/820433_EA288.pdf
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old February 22nd, 2019, 05:22   #7
JM Popaleetus
JM Popaleetus's Avatar
I have never heard of preemptive changing of a thermostat. Water pump, and everything else the belts touch? Sure.
Unless you thermostat throws a code I wouldn’t worry.
2015 VW Golf TDI SEL (DSG, Lighting and Driver Assistance Packages, Tornado Red/Titan Black)
2007 GMC Sierra 2500HD Classic (Duramax LBZ, SLT, Extended Cab, Summit White/Ebony)
2013 VW Passat TDI SEL Premium] Buyback
2010 VW Jetta TDI RIP
JM Popaleetus is offline   Reply With Quote
Old February 22nd, 2019, 07:55   #8
Toyomike
TDI(s): 2004 Golf
The service interval does say 130k, but thereís no way Iím chancing it breaking. Iíll pay the money and change it at 100k.
Old February 22nd, 2019, 10:23   #9
Ol'Rattler
Ol'Rattler's Avatar
Unless you thermostat throws a code I wouldnít worry.
T-Stats are not monitored by the ECU............
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old February 22nd, 2019, 17:38   #10
JM Popaleetus
My 2004 Trailblazer could throw a CEL and tell me if the thermostat was stuck open or closed. Iím sure a 2015 VW could.
Maybe Iím wrong, maybe they do have a replacement interval. I myself have just never heard of that.
Old February 22nd, 2019, 23:34   #11
turbobrick240
turbobrick240's Avatar
I haven't seen any interval listed for the EA288 thermostats in the maintenance schedule. 130k miles is for the timing belt. VW seems to view them like an alternator, you replace it when it goes bad.
Old February 26th, 2019, 11:51   #12
740GLE
may i recommend you also change out the oil pump belt as well? I mean PM is PM and you can never be too safe avoiding parts failures.
How often do you change GP and injectors?
Old February 26th, 2019, 14:45   #13
bizzle
bizzle's Avatar
These cars have been sitting for over a year so a bit more than normal PM isn't overkill, imo.
That's a different issue from not being able to source a new tstat, which is concerning regardless of when it should be replaced.
bizzle is offline   Reply With Quote
Old February 26th, 2019, 14:55   #14
turbobrick240
These aren't your typical cheapo automotive thermostats. VW made them pretty durable because they are such a pita to get at. That's also why there is no interval.
Old February 26th, 2019, 15:02   #15
bizzle
bizzle's Avatar
Cheap or not, there have been several gurus posting that TDI tstats fail slowly without owners realizing it with predictably poor fuel mileage as a result. More to the point, these specific cars have been in holding for an atypical period of time--we may only have around 100k on them but they're five years old now.
The tstat on my beetle was about $15 bucks for everything including the housing. Holding it in my hand doesn't distinguish it from any other tstat I've ever replaced, but maybe my EA288 one is ultra fancy. Not sure of how difficult it is to get too, but placement doesn't really mean much to me in terms of the manufacturer's design. The oil filter is the same ole one, too, but it's definitely more of a pita to get to than my 2012.
Anyway, the point isn't whether one owner should replace the tstat; he wants to change it and no one knows where to get one is the thread's topic as far as I read it. I didn't see him asking us opinions whether he should change it...although since it's publicly posted people can post their opinions but they've already said their piece so no real reason to belabor the point if you think he doesn't need to change it, right?
thermostat replacement csnow VW MKV-A5 Golf/Jettas 4 November 27th, 2013 09:49
Thermostat replacement how-to dgoldsmith VW B5 Passat TDIs 32 November 19th, 2013 09:07
Thermostat replacement cconrad VW B5 Passat TDIs 8 October 25th, 2013 08:58
Thermostat Replacement irbk TDI 101 12 October 6th, 2008 14:16
Thermostat replacement Jamesmbolan TDI 101 4 February 12th, 2007 11:45
Page generated in 0.16336 seconds with 13 queries
[Output: 127.12 Kb. compressed to 105.91 Kb. by saving 21.22 Kb. (16.69%)]
