When I ohm'd the glow plugs as the forum suggested I had one glow plug that had a very high reading and needs to be replaced. How do I know if they are Bosch or Beru? Should I replace all 4?
Same problem with mine. One plug faulty. Replaced all 4 glow plugs. Did not replace the harness. Remove code from ECU and be happy. CEL has been off ever since.
